#4 Rocker arm broke
Old Aug 3, 2010 | 03:59 PM
Altitude Adjuster's Avatar
Default #4 Rocker arm broke
Found Broke #4 Rocker Arm. Has anyone replaced just one rocker arm or do you still have to pull the hole head. Any tricks would help not having to pull the head.
Old Aug 3, 2010 | 04:09 PM
Mdub707's Avatar
Pull the valve cover, you should have no problem replacing it without taking the head off. I would be more concerned as to WHY that happened. It's not completely unheard of, but most of the ones I've seen break are because the valves stuck in the guides, which resulted from blown headgaskest. The coolant leaked in enough that it corroded the valve guide and the valve stuck in the guide, then the piston smacked it...
Did anyone look down in the cylinder? Was there a compression test done on it?
Old Aug 4, 2010 | 08:56 AM
The heads are reman. and his receipt he has 1200 miles on them with Arp's and gaskets. I believe it was over revved maybe with the edge on it this truck gets no mercy customer stated after heads were done truck was pulling 38lbs of boost and before the heads it was pulling 27lbs. tops. But i will do a compression check and borescope to see the piston. Thanks for the help again Mdub
Old Aug 4, 2010 | 08:20 PM
Mdub707's Avatar
I run over 35psi daily with my SCT as well. I run to 4200 rpms as well. Haven't had any issues of late, but I have blown 2 sets of headgaskets, one set was with ARP's installed. I am now back to stock junk TTY bolts but still running hot tunes and no issues now so!?
Old Aug 5, 2010 | 09:47 AM
paul h's Avatar
It is reported that when doing head studs you have to put the push rods and rockers in place and tight before you torq the head bolts. They will bend push rods or break things if you don't
tylerjp34
Sep 16, 2015 03:12 PM
Jmrobinson
Aug 20, 2015 07:56 PM
Dieseltech0593
May 7, 2015 08:10 PM
99dodge
Dec 15, 2014 04:56 PM
