Dodge 1st Gen & Cummins Parts.
Old Aug 3, 2010 | 03:47 PM
Mark Nixon's Avatar
Default Dodge 1st Gen & Cummins Parts.
I have many, many 1989 through 1993 Dodge Cummins parts, engines, transmissions, trim parts, interior, exterior, fenders, doors, hoods, grilles, tailgates, beds, dually, single wheel, 4x4, 2x4, axles, 3.07, 3.54, 4.10, transfer cases, 23 spline, 29 spline, you name it, I may have it.
If I don't have it, I can probably help you find it!!!
The following is a list and condition of parts trucks that I have on hand.
Some can be had as PROJECTS:
1992 D-350 C/C Dually, very rusty, runs & drives, no rear fenders, solid fenders, good I/C core support.
1991 (Intercooled) w-250 Cab/frame, HAS 3.54 axles and np205 29 spline T-case, rustfree 5 speed 4wd cab w/gray interior.
1991 (non-I/Ced) w-250 Cab/frame, HAS 3.07 axles, np205 23 spline T-case, rustfree auto 4wd cab w/red interior.
1990 4wd w-250, has complete (excellent running) engine, also has a 5 speed (needs rebuilt) and np205 29 spline T-case, truck is complete minus axles and bed, BUT it is extremely beat up and would need a front clip and doors.
1989 2WD D-250, 1 ton on singles, decent, usable Texas body with very burned-up paint, no engine, has transmission and 3.07 rear axle, basically just needs an engine, a patch in the front bed floor (rust) and some TLC.
Call 402-780-5127 or E-mail me at Nixon340@yahoo.com
I ALSO DO TRADES AND I CAN DO LONG-DISTANCE TRANSPORT ON WHAT I SELL!!!
Old Aug 3, 2010 | 06:48 PM
wisconsin redneck's Avatar
you have any 2nd gen stuff?
Old Aug 4, 2010 | 10:25 AM
Mark Nixon's Avatar
Very little, I don't actively search for it.
What are you needing?
Mark.
Old Aug 4, 2010 | 11:02 AM
jumpnjed's Avatar
Do you have the arm rest for a 93?..Mine are the grey ones. I would need both sides if you have them...
Old Aug 4, 2010 | 12:55 PM
white93's Avatar
Would you happen to have a set of stock intercooled injectors?
Old Aug 6, 2010 | 01:08 AM
Mark Nixon's Avatar
jumpnjed, I have both armrests, driver's side is decent, as is the passenger's side, $30, shipped on the pair.
white93, I have a set of '92 injectors with @130,000 miles on them, been out of the engine for a while, $150, shipped.
Mark.
Old Aug 8, 2010 | 05:57 PM
hey mark i forgot i posted in here... but im looking for a np 241 transfer case i think... ill have to go double check
yes it is a 241... heavy duty
Last edited by wisconsin redneck; Aug 8, 2010 at 05:57 PM. Reason: Automerged Doublepost
Old Aug 9, 2010 | 03:25 PM
98cummins's Avatar
Looks like your the guy I need to talk to. A coworker of mine just gernaded the 5 spd in his 92 ram 250 4x4. He doesn't use this site but is in pretty desperate need of a tranny so he can keep getting to his tractor pulls. What do you have in that line of stuff? Idk what you all need to know his is intercooled and 4x4 located just north of Fargo, ND. The sooner I know somethin the sooner I can have my truck back. Thanks
Old Aug 10, 2010 | 01:37 PM
Budgreen's Avatar
I need all 4 grille inserts for a 93, pretty sure a few earlier years work also. how much if ya got em
Old Aug 11, 2010 | 05:34 PM
Mark Nixon's Avatar
Wisconsin Redneck, I MIGHT know of a 5 speed 241 DHD, which is what yours should be.
I may know something soon, a local guy has one.
98Cummins, he called, we talked, twice.
Budgreen, I have a set of 4 inserts, $30, shipped.
Mark.
