TC Lockup Switch Help
Old Aug 2, 2010 | 01:55 PM
Cummins Smoke 24v's Avatar
Default TC Lockup Switch Help
ive been trying and trying to get make my own Torque Converter lock up switch for my 98.5 Cummins 24v and i am not having any luck that TST website link aint helping so please help me wire it up or post pics.. i really want to do it!
Thanks!
Old Aug 2, 2010 | 03:13 PM
jaytric9's Avatar
where are you having trouble? what do you have done so far?!
Old Aug 2, 2010 | 03:33 PM
ted66's Avatar
on PCM pin #11 org/blk wire is the driver wire. sensor ground is pin #4 blk/lt blue. or just use chassis ground. hope this helps. oh PCM is right side of firewall
Old Aug 2, 2010 | 03:45 PM
well got back from the autozone and i took off the fuse box under the hood pulled the big fuse out for the tranny like it says on TST website. got the test light out and as soon as i tested it,it blew another fuse i dont get it... oh and i put the new fuse back on and it felt like i had a heavey pedal but it fixed itself..
VERY CONFUSED!!!!
Old Aug 2, 2010 | 03:56 PM
ted66's Avatar
VERY CONFUSED!!!!
didnt know you had the TST i miss understood or something i thought you wanted to hook up your own switch.
Old Aug 2, 2010 | 04:24 PM
yes i do sorry bout that i want my own switch i went on to tst and there is a link on how to wire one up but it didnt help so i need some help
Old Aug 2, 2010 | 05:07 PM
RAW's Avatar
RAW
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
Does this help at all?
Old Aug 2, 2010 | 05:21 PM
na thats the link that didnt help i need pics of someone doing it haha!
Old Aug 2, 2010 | 11:23 PM
Russ Roth's Avatar
Tap into the orange/black wire on the passenger side firewall. Run that wire to your switch. Run the other side to ground. Solder into the ground wire a Radio Shack 33 ohm resistor, part #271-1104. You should be done if your connections are all good, you got the right wire and you installed the resistor facing the correct direction.
Old Aug 2, 2010 | 11:42 PM
Can you try to post some pics up??
