J - Hook??
Old Oct 12, 2007 | 10:40 AM
Bucket Truck's Avatar
Default J - Hook??
If I run 100hp. injectors with my Quad XZT+ would a j-hook help make more boost and keep egt's down? Or would it make egt's go up? Should I not worry about the j-hook. I thought it might help alittle til I got a bigger turbo.
Old Oct 12, 2007 | 11:06 AM
DazedandConfused's Avatar
You can set it to run around 32PSI of boost and it will help very little. You will be needing a charger to keep it cool if you want to run it hard. I'm guessin you have the HY35? I do to and can burry the Pyro with just the edge on 5 if I hold it to the floor for about 35-45 seconds.
5.9Cumminsturbodiesel
Audio Equipment/Electrical
Nov 19, 2014 07:45 PM
