Leveling Kit
Old Aug 1, 2010 | 09:11 PM
firstdiesel's Avatar
Default Leveling Kit
I purchaced the spacers for the front end, and my question is do I need to buy new shocks as well? And also I'm I gonna need to get an alignment also?
Any info would be nice thanks.
Old Aug 1, 2010 | 09:20 PM
turbo20psi's Avatar
You should buy new shocks.Yes you will need a alignment.Might want to check the ball joints,tie rod ends,trac bar ...ect.While you are at it.Shocks I recommend Bilsteins 5100s.When you raise it check for center so your axle is lined up correctly.
Old Aug 1, 2010 | 09:21 PM
J-Pipes's Avatar
Yes, get an alignment, I didn't till I relized that I was destroying my right front tire! It was over 1/2" out on the toe in.
Old Aug 1, 2010 | 09:29 PM
What about drop brackets for the sway bars, are they necessary.
Old Aug 2, 2010 | 07:16 AM
turbo20psi's Avatar
No not on a leveling kit.I change my sway bar end links on mine because the ball joints were wore out.
Old Aug 2, 2010 | 07:24 AM
I saw some kits with the sway bar drop mounts. Just checking. Thanks
I guess it is time to hit up some sponsors for the shocks
Old Aug 2, 2010 | 08:52 AM
NadirPoint's Avatar
Every part with alignment or poistioning affected by the ride height needs to be addressed: Sway bar, control arms, track bar, shocks, steering.
You can get away with doing more or less with some things. For example, adjusting the control arm eccentrics forward. But anything not corrected for ride height is a compromise that affects ride and handling and basically results in a half-assed lift to some degree.
Old Aug 4, 2010 | 07:24 PM
how hard is the kit to install? How long will it take me?
Old Aug 4, 2010 | 08:37 PM
turbo20psi's Avatar
Its not hard if you have a lift.It took me 3 hours but I also changed the shocks and sway bar end links.Do have a lift you can use it will be easier and safer.
Strictly Diesel
Strictly Diesel
Sep 17, 2015 05:11 PM
KRYPTONITE
6.7 Liter Dodge Cummins 2013+
Jun 16, 2015 09:40 AM
biged681985
For Sale
Apr 28, 2015 04:26 PM
Gman30
Dec 27, 2014 12:46 PM
DirtyMonkey
6.7L Performance 2013+
Oct 19, 2014 11:16 PM
