Installing Tranny temp sensor advice?
So I need advice on installing my sensor.
I know its going in the hot line running to my cooler. But how do I install a sensor into a line? I'm not really following whats going on there.
Anybody got a good write up or some pics?
I've been told the easiest way is to go get a line from a 92-96 with a spot for the stock sensor built in. (I drive a 98 so my sensor is apperantly eslewhere)
Thanks for the help!
you can always go down to your local hardwae store and get a brass tee. get two barbed ends and stick it into the lines and put the plug on the 3rd end. thats what i did when i had my auto trans, cost like 12 bucks i think
put them in get compression fittings and a T and put them in the hard line that leaves your TQ (hottest place the fluid gets). then you will know the exact second when you are burning up those spendy parts. the lines ar 1/2 inch.
jrad989 how do u do that with a long probe like what i have i put mine in the side of the tranny because i tried alot of different ways and that probe that came with my gauges was too long for anything else?
Haha, I have a glowshift 3in1 to mount on my Steering colum.
I need to hook up the power wires and tranny sensor but other than that I have the manifold and intake drilled with sensors in.
