fass ddrp lift pump pressures?
Old Jul 31, 2010 | 10:55 PM
98dodgecummins's Avatar
Default fass ddrp lift pump pressures?
well about a month a go my truck was pushing 20 psi of fuel pressure at idle and 12 at wot but now my lift pump idles at 15psi and now i barely get on it my fuel pressure goes to 10 really easy what could make my lift pump start to not push as much fuel ?
Old Jul 31, 2010 | 11:00 PM
RAW's Avatar
RAW
Have you tried changing the fuel filter? It's a pretty cheap fix if that's the problem.
Is pressure confirmed by a mechanical gauge? Pressure sensor may not be reading correctly.
Old Aug 1, 2010 | 09:36 AM
well i thought it was my fuel filter too but i changed it and it did not change nothing?
i got a glowshift fuel pressure gauge.
Last edited by 98dodgecummins; Aug 1, 2010 at 09:36 AM. Reason: Automerged Doublepost
Old Aug 1, 2010 | 11:29 AM
Glowshift = Junk
Old Aug 1, 2010 | 03:17 PM
their not junk theirhas to be something wrong with my lift pump to not push as much fuel pressure is their any way i can know for sure?
none of my gauges are messing up its just my fuel pressure is lower. my gauge is accurate. could this be a problem i have been having electrical issues and could it be messing with my lift pump to not push as much fuel?
Last edited by 98dodgecummins; Aug 1, 2010 at 03:17 PM. Reason: Automerged Doublepost
Old Aug 1, 2010 | 03:22 PM
captain_stabbin's Avatar
if you have a bad or loose ground it will not give it full power i would think
does the pump sound weak ?
Last edited by captain_stabbin; Aug 1, 2010 at 03:22 PM. Reason: Automerged Doublepost
Old Aug 1, 2010 | 04:18 PM
crzycummins's Avatar
check all connections. make sure of good filter. be positive your gauge is reading correctly. check voltage of lift pump.
Old Aug 1, 2010 | 04:56 PM
01quadcab's Avatar
have you checked your fuel pressure against a mechanical gauge to be sure it's working correctly? the ddrp could be going out or have something stuck in it. These pumps need a pre-filter on them. and yes glow shift= junk. They are not very accurate.
Old Aug 1, 2010 | 05:52 PM
tburke's Avatar
I tried a DDRP on my truck for a short time, it idled at around 20 but I could not even try WOT without it dropping to below 5 even on the stock setting on my juice.
Old Aug 1, 2010 | 08:46 PM
well i guess i have an in tank pump and a ddrp because with my 65 hp injectors and edge comp before i was having problems with my fuel pressure i could put my comp on lvl 3 and i could get on it hard and it would stay at a strong 10 or 11 but now with my comp box turned off and giving it middle fuel it goesm down to 10 really easy. ????????????
is it just me or does a fuel box give power to the truck even if it is turned off???????
what should be my voltage on my lift pump and how can i check it?
Last edited by 98dodgecummins; Aug 1, 2010 at 08:46 PM. Reason: Automerged Doublepost
