6.2 swap
Old Jul 31, 2010 | 04:43 PM
latenighthaulers's Avatar
Default 6.2 swap
ok i have a 90 3500 i just got and i want to put a 6.2 in it it has a 350 in it right now what will i need will the tranny bolt up? any help would be great. Thanks guys!
Old Jul 31, 2010 | 06:00 PM
Woody35's Avatar
what tranny is it?
Old Jul 31, 2010 | 06:29 PM
700r4
Old Aug 1, 2010 | 08:59 AM
Livelli's Avatar
2wd should be as easy as a diesel torque converter and govenor. If it's a 4wd then you have some support hardware to worry about. If the 6.2 is out of a 4wd then there will be plates at the motor mounts with holes. These holes (I'll find some pics) are where you mount support rods (6.2/700r4 specific) that connect down to the torque converter cover (also specific) for strength. Believe me, this stuff is crucial! I've broken three, count 'em, three transmissions in less than a month without this stuff up there. The parts aren't the least easy to find, but they're close. I have links and part numbers if you need them.
Old Aug 4, 2010 | 11:08 AM
lcschoe's Avatar
I am curious...what govenor are you referring to? I swapped the transmission (700r4) from a 85 4wd blazer w/ a 305 gasser to a 82 4wd blazer w/ a 6.2 and only changed out the torque converter. It runs fine, but now I am wondering if I missed something.
Old Aug 4, 2010 | 05:29 PM
2MuchJunk's Avatar
There is a governor in the trans that helps determine shift points. If it shifts at a good rpm and doesn't bog or over rev then its fine.
Old Aug 4, 2010 | 05:40 PM
92typhoon937's Avatar
id leave the 350 in it
Old Aug 4, 2010 | 09:14 PM
purcell87's Avatar
X2.
Id say thats grounds for a Cummins swap.
Old Aug 4, 2010 | 09:44 PM
Woody35's Avatar
you kidding me 6.2 is a lot better than a 350
Old Aug 4, 2010 | 10:04 PM
2MuchJunk's Avatar
13mpg with my 350. 25 mpg with my 6.2 I have to say I like the 6.2 better.
Cummins swap! You need to go repent for your sins.
