turbo surge??
Old Jul 30, 2010 | 06:26 AM
fcramrj's Avatar
Default turbo surge??
why am i getting turbo surge??? and how do i stop it?
Old Jul 30, 2010 | 09:53 AM
kazairl's Avatar
Some information about your truck would be nice.
Old Jul 30, 2010 | 10:37 AM
fcramrj's Avatar
01 dodge 2500 24v, quad boost fooler, smarty, smoke switch, 5in straight pipe, 3in body, 35" bfg, high flow intake,
Old Jul 30, 2010 | 11:00 AM
kazairl's Avatar
Stock Turbo? When does it surge? If it only does it when your running high boost and suddenly back out of the throttle then its pretty normal. The solution is to not back out of the throttle so fast.
Old Jul 30, 2010 | 12:11 PM
fcramrj's Avatar
stock turbo. and that is what it is doing, when i get into it then get off it surges. i heard that was not good. but i aint for sure. thanks
Old Jul 30, 2010 | 04:32 PM
kazairl's Avatar
It depends on how hard it does it. The slang term is "barking the turbo". When you back out of the throttle quickly you loose most of your force that spins the turbo. However the intake tract is still full of pressurized air which finds the easiest path out, back through the turbo. When it does this it can either stop the turbo from spinning or decelerate it almost instantaneously which is rather hard on parts.
However with a stock turbo and pretty stock fueling I don't think you can surge it hard enough to hurt it.
Old Jul 30, 2010 | 06:03 PM
RAW's Avatar
RAW
I disageee on that last thought. When I first bought my dodge I drove it like a gasser and had the same issue. I quickly adapted my right foot agressiveness to change this. Barked my HY a few times, before the 65's and EJWA on stock mode. There are "blow off" products available but pulling out of the throttle a little slow will give the same results.
Old Jul 30, 2010 | 11:05 PM
kazairl's Avatar
I didn't say you couldn't do it. I just don't think it will be severe enough to break something. Though I should amend that by saying the more often you do it the likelier it is to break.
Old Jul 31, 2010 | 12:11 AM
RAW's Avatar
RAW
Very true, either way it is bad. It will happen if your not careful, and do be aware of it. Damage can happen, and more with higher boost pressure.
Old Jul 31, 2010 | 09:54 AM
wyodiesel92's Avatar
Mine tends to do this all the time despite my efforts, maybe its more difficult to avoid in a 5 speed? It'll do it even when I'm only pushing like 15 psi sometimes.
