Injector size question.
Old Jul 29, 2010 | 10:18 PM
white93's Avatar
Default Injector size question.
I'm trying to identify what injectors are in my truck. The number on the side is 9350 and they are a light grayish color. I think they might be pod's because I can't control egt's when I tow trailer and they haze pretty bad at idle.I can break the tires loose in 2nd,3rd, and 4th gears once the turbo lights and the power screw is only 1 turn in.
Old Jul 30, 2010 | 09:15 AM
1STGENFARMBOY's Avatar
I believe you have 40 hp DDP's because the part # is 899350lpm, so the 9350 kinda fits into that.
Dar
Old Jul 30, 2010 | 06:06 PM
JBradley500's Avatar
bosch has a part with that number i believe. they used to sell them on ebay if im not mistaken.
Old Jul 30, 2010 | 06:33 PM
white93's Avatar
I'll pull them out and get the number. I plan on putting bosch 190's in to help with the fuel mileage,right now it only goes 150 miles on a tank when towing 8500lbs.
Old Jul 30, 2010 | 06:40 PM
big bad diesel 416's Avatar
Site Sponsor
150M to 30G of diesel thats only 5MPG!!!!!!!
The ole girl needs some help i dont ever think I have heard of getting 5MPG in a cummins unless it was running on 2 cylinders..........
Old Jul 30, 2010 | 08:01 PM
white93's Avatar
I was shocked to,I stopped a few times to make sure the pump wasnt leaking or dumping fuel into the crankcase. The 12 valves at work in the buses get 4.5-6 mpg,but i didn't think it was possible in a pickup. Ive been having pump problems too so its time for a total injection system overhaul.
Old Jul 30, 2010 | 09:29 PM
ArizonaRedneck's Avatar
go to search at the top right hand side and put in 1st gen injectors lots of good info there
Old Jul 30, 2010 | 10:33 PM
white93's Avatar
Well I did a search and I think I may have a cracked tip. Will I need to get new copper washers if i'm only pulling them to look at?
Old Jul 31, 2010 | 01:07 AM
Site Sponsor
no there just like a washer not like a seal they can be reused if that makes sence
Forks diesel nut
Diesel Engine Conversions
Jul 27, 2015 12:19 PM
torg73
May 11, 2015 03:08 AM
99&91cummins
Mar 4, 2015 01:56 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
