Rough Idle Loss of Power P0272 Code
Old Jul 29, 2010 | 03:36 PM
Altitude Adjuster's Avatar
Default Rough Idle Loss of Power P0272 Code
I have a customer that had reman heads, Arp studs done about 1200 miles ago. Came in today with the P0272 code and rough idle and loss power blowing blue smoke. We ohmed the injector and everything is reading normal. Does anyone have any suggestions? Bent valve, spring, cracked piston?
Old Jul 29, 2010 | 04:18 PM
Lange503's Avatar
possibly heads are warped?
Old Jul 30, 2010 | 11:24 AM
MUDSTROKIN''s Avatar
i'd check the FICM and see if the voltage is correct.
Old Jul 30, 2010 | 03:39 PM
Diesel Powered Rocket's Avatar
If you slightly accelerate the engine off of idle, does the engine smooth out? Clear any codes before trying this test.
Old Aug 1, 2010 | 01:24 PM
Mdub707's Avatar
cylinder 4 contribution fault. If you clear the codes and you keep getting this ONE code, it's probably just the injector. It's also possible it's leaking there as well, bad o-ring or possibly the injector is loose in the cylinder.
Old Aug 3, 2010 | 03:20 PM
Found problem tested the injector,ficm and cleared codes. Pulled valve cover and #4 rocker arm was broke, and a bent pushrod. Has anyone replaced a rocker arm without pulling the head just wondering if there was a trick instead of pulling it.
Old Aug 3, 2010 | 04:06 PM
Mdub707's Avatar
Yeah You have to pull the rocker arms to get the heads off last I knew, so you should be able to change that without removing the head. Lets just continue the chat on the new post...
Old Feb 24, 2012 | 07:05 AM
jlove2003's Avatar
I have a buddy who has this exact problem, if it clears up when accelerating or increasing idle what does that narrow it down too?
Old Feb 24, 2012 | 09:30 AM
Mdub707's Avatar
bad injector most likely, but hard to say with so little information. Test the FICM too.
timracerx
Apr 14, 2015 10:28 AM
Bighouse
Apr 9, 2015 06:51 PM
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
15
Dec 8, 2014 08:46 PM
99stackedpowerstroke
Oct 8, 2014 07:06 PM
