wastegate actuator
Old Jul 28, 2010 | 09:05 PM
Diesel55's Avatar
Default wastegate actuator
I have a 2001 dodge 2500 cummins 5.9 24 valve. I was wondering if its a good idea to plug the wastegate actuator?
Old Jul 28, 2010 | 09:12 PM
RAW's Avatar
RAW
It has been said that it will reduce turbo life, and may cause turbo failure. If your looking for quick boost until a better turbo shows up, go for it. Running it long term is not advised. I ran my HY35 with a plugged wastegate for over 6 months, went from 18PSI to 29PSI boost doing so. That old HY35 still had good end play and side play when I sold it to a coworker. To this day it is still holding up just fine.
Old Jul 28, 2010 | 09:37 PM
Diesel55's Avatar
i have heard that without a programmer with a boost fooler it will rob power... is this true?
Old Jul 28, 2010 | 09:59 PM
RAW's Avatar
RAW
I kinda doubt that, but can't say for sure. Only one way to find out, eh?
Old Jul 29, 2010 | 08:56 PM
JSPulliam21's Avatar
Been running mine plugged for almost 4 years and 50k. No issues. Sees 40 psi daily.
Old Jul 29, 2010 | 08:59 PM
BlackCloud96's Avatar
Been running my hx35 plugged since 2007 and 40k same issue no problem 40 lbs of boost all day long!
Old Aug 4, 2010 | 08:13 PM
01greenmachine's Avatar
Without a boost fooler or a programmer a 2001 will de-fuel at about 21.5 psi and prob set a code as well . I run 35 psi on mine with no prob for 90000 miles. Boost doesnt make power fuel does.
Old Aug 6, 2010 | 01:12 AM
zeigler86's Avatar
actually, they both do. an engine is just an air pump. the more air in and out the more power and the more efficient. just my 2 cents. it gets to a point that it can be over fueled and lose power compared to a good air/fuel ratio.
block it off and see what it gets you. mine has been blocked for a long *** time with no problems.
Old Aug 6, 2010 | 04:13 PM
24vcumminscowboy's Avatar
i went with that bd boost elbow its done me good no boost foolers or programmers and i hit 25psi easy and dont get any codes not sure why
Old Aug 10, 2010 | 06:21 PM
Cummins Smoke 24v's Avatar
how do you block off the wastegate?? i know you can get a boost elbow but im a cheap *** anything homeaid?
bigblu
18
May 10, 2015 10:52 AM
wpg6.5
Feb 19, 2015 07:27 PM
pitbulls3489
Jan 29, 2015 08:41 AM
