EGR cooler
Old Jul 28, 2010 | 05:09 PM
eric guerin's Avatar
Default EGR cooler
Does anybody know how hard it is to change the EGR cooler and where can i find directions on how to do it.
Old Jul 28, 2010 | 05:58 PM
esetzer's Avatar
you can go to BULLETPROOFDIESEL's website.. they have a PDF file on installing their upgrade coolers... it isn't too hard... but it does take some time.... might as well change your oil cooler while your in there too.....
Old Jul 28, 2010 | 08:58 PM
justintimemoto's Avatar
did you consider deleteing it? when mine goes bad its going
Old Jul 28, 2010 | 09:11 PM
esetzer's Avatar
I did consider just deleting it actualy. this is why i didnt... At the time i thought i only had a cooler issue. I have a 2006 6.0. i you delete the cooler/egr valve on them they will run a EGR code. At that time i had not installed head studs and didnt want to run the risk of blowing a head gasket due to running a tuner 1) to clear the code 2) for more power, MPG, etc.etc. so i ran with Bulletproofdiesel's EGR cooler. I think it is a better (more proper fix) in my mind. yes you can gain some better MPG if you take out the EGR... but the problem is still there sort of. sand in the coolant system that is the cause of the failed oil and EGR cooler (clogging). So... I added a Bypass coolant filtration system, changed the coolers and rode with it. I never have had an issue since. I never had code issues since i still use my EGR valve. I take it out and clean it about every other oil change.... and mine hasn't failed yet. Since then my head gaskets have blown... so my heads are stud'd via ARP, so it doent matter now.... but i didnt delete it then due to not wanting Computer issues etc.etc. Hope that makes sence. My repair took care of the original issue... the coolers and why they failed (casting sand left over from production) (thank you Navistar) and i corrected those issues the right way.. with a way to get the sand out and an improved EGR cooler that will not clog as the old ones will. I am currently awaiting on my SCT in the mail now since i have THOSE STUDS!!!!!!!! hope that makes sence to you the way i said it.....
syctaz
Jun 26, 2015 12:20 PM
Bighouse
Apr 9, 2015 06:51 PM
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
bypass-21
Dec 15, 2014 08:52 AM
perk7089
Nov 5, 2014 06:41 PM
