True Performance Diesel Visit - True Performance Diesel
TPD 94-03 Ford PS HPX Lines
Old Jul 26, 2010 | 07:04 PM
TruePerformanceDiesel's Avatar
FormerVendor
Default TPD 94-03 Ford PS HPX Lines
True Performance Diesel is proud to offer:
TPD's High Pressure Crossover Lines for 94-03 7.3L Powerstrokes.
This simple upgrade will smoother idle, quieter injector operation and maintain even oil pressure on all injectors.
Don't be fold be other kits using rubber hoses that deteriorate over time.
TPD uses high quality steel braided line and fittings.
We are now taking orders for the first batch.
Check out the Group Buy page for updates.
https://www.dieselbombers.com/group-...group-buy.html
Also look for TPD's Air Intake Systems in the coming weeks.
Old Jul 28, 2010 | 01:46 AM
12vcummins96's Avatar
Yes it is. Its made out steel braided line rated at 4k psi. As said above it smoothes out idle and quiets injectors
4k psi is all they are rated ive seen hpops hit 4k so those lines are hitting burst psi
im just asking
Old Jul 28, 2010 | 11:20 AM
FormerVendor
im just asking
Just for your information the burst pressure on that line is 16k psi rated operating pressure is 4k. The HPOPS system dumps pressure at 3K thanks to the ICP valve. The only time you'd see 4k is if you lift throttle after full throttle run. i.e. dyno pull.
Old Jul 29, 2010 | 01:55 PM
hey bud im not tryin to challenge you was tryin to clarify so calm down easy guy
Old Jul 29, 2010 | 04:20 PM
FormerVendor
Didn't mean to take it out on ya like that. Was venting alittle.
Old Aug 7, 2010 | 02:20 PM
FormerVendor
Default Only 2 left!!!
Out of a batch of 25 we're down to 2.
The finalized price for these is $39.93
Old Sep 14, 2010 | 10:34 PM
7.3pokesfan's Avatar
If you still have any ill take one!
Old Sep 14, 2010 | 11:27 PM
FormerVendor
Old Sep 28, 2010 | 02:11 PM
FormerVendor
Default Hot and Fresh
Fresh batch of these just got done yesterday.
These make a great adition to stock truck or a wild racer.
Old Oct 10, 2010 | 12:37 AM
Rustin's Avatar
I would advise if your running the oil crossover tube ,and you have an older modle truck like an early 1999 or older. Up grade your High Pressure Oil Pump. those are good tubes I am picking up one!
Thanks TPD!
