fuel leak in 6.5
Old Jul 26, 2010 | 09:06 AM
supera48's Avatar
Default fuel leak in 6.5
changed fuel filter, now i have a drip under the passenger side below the starter. i only see it after stopping and parking the truck. Cant find the source of the drip. the filter canister feels dry. any thoughts??
Old Jul 26, 2010 | 09:29 AM
Woody35's Avatar
fuel return line slipped off?
Old Jul 26, 2010 | 02:05 PM
supera48's Avatar
maybe, i haven't checked very deep yet . just thought someone had an idea before i dig in. thanks
Old Jul 26, 2010 | 02:12 PM
Woody35's Avatar
have you replaced your injectors lately?
Old Jul 27, 2010 | 07:31 AM
supera48's Avatar
No, I bought the truck new in 95. 200000 miles , same injectors
Old Jul 27, 2010 | 05:03 PM
Woody35's Avatar
well some chinese injectors leak but at 200000 miles there probably do to be changed soon. any more clues on the leak.
Old Jul 28, 2010 | 06:25 AM
supera48's Avatar
going to look at it after i get off from work this afternoon. maybe something obvious.
thanks
Old Jul 28, 2010 | 06:57 AM
steel's Avatar
Seem like the rubber lines that run to the filter base crack and wear out. if u moved the filter base at all even tho its bolted to the intake they break. return lines off the injectors are a joke and seem to leak alot to.
Old Jul 28, 2010 | 08:08 AM
DieselSlug's Avatar
If you get a fuel leak anywhere in the valley of the engine it runs down a small hole and down the back by the bellhousing. Check to make sure the filter is properly seated in the canaster, if you moved any fuel lines they are bound to be cracked if original. Take out the two bolts holding the canaster in so you can move it around and check for leaks. Really need to get new injectors, at that mileage you will notice a power increase with new ones. Dont buy ebay cheapos tho, you get what you pay for in injectors.
Old Jul 28, 2010 | 08:24 AM
supera48's Avatar
thanks
