1st gen dodge clutch hydros
Old Jul 25, 2010 | 06:11 PM
jake_evans's Avatar
Default 1st gen dodge clutch hydros
looking for clutch hydros for a 1st gen. must be in good condition.
Old Jul 25, 2010 | 07:17 PM
tltruckparts's Avatar
i have a BRAND NEW never even used slave cylinder for a 1st gen. email me at tltruckparts@hotmail.com if interested. i think i even have a master cylinder too i may have the hydraulic line as well
Old Jul 25, 2010 | 09:36 PM
jake_evans's Avatar
Im kind of looking for the sealed unit since there is no way to bleed the system. I mean there is no bleeder, and im having that problem with mine now. Its not leaking but i cant get it bled. Idk what do you think?
Old Jul 25, 2010 | 09:48 PM
there is a way to bleed. it is not truely a sealed unit. you just have to know how to do it. its easiest to do it with everything out of the truck on a bench
Old Jul 26, 2010 | 04:27 PM
jake_evans's Avatar
Can you explain how to bleed it for me and for others?
Old Jul 27, 2010 | 10:24 AM
Mark Nixon's Avatar
Old Jul 27, 2010 | 10:58 PM
it would take me an hour to write it up. its super confusing trying to explain it on the internet. i called southbend and asked them how to bench bleed it they were very good at explaining it.
ill get those pics sent to you tomorrow after i get off work
Old Jul 28, 2010 | 05:10 PM
Mark Nixon's Avatar
Basically, on a used one, you can hang it on a wire, master up, then position the reservoir (full of fluid and cap lightly tightened, to aid in removal to top off fluid) above the master cylinder on another means of support.
You then only need to move the slave piston, using the pushrod inward and outward by hand, SLOWLY.
Watch the reservoir for both fluid level and bubbles.
Keep stroking the piston on the slave cylinder back and forth until there are no bubbles coming into the reservoir.
A new set-up has a zip-tie like piece to keep the pushrod from getting lost.
Cut the tie and do as instructed aboove
In truth, it takes little more time to bleed it than it did for me to type all of this and despite how complicated it may seem, it is reallly very simple...
Air will rise in liquids, and liquids displace air easily.
This took me 4 minutes to type.
Mark.
Old Jul 30, 2010 | 10:39 AM
jake_evans's Avatar
Thanks mark. I have done that on the truck by removing the slave and pulling it straight down then pushing the rod in and out slowly, but its just not as good as it could be. I could see where doing it on a bench you could get it better though.
Hey "tltruckparts" you got those pics yet? And a price?
Old Jul 31, 2010 | 06:44 PM
i looked around today it looks like all i have left is a brand new slave cylinder. if your itnerested let me know its brand new i didnt get a picture of it because its the same as every other one youll see from oreilly or napa or whatever.
Cdog121
Nov 16, 2015 01:49 PM
Tory4
For Sale
Feb 1, 2015 08:33 PM
ajpt6.9
Dec 4, 2014 12:06 PM
JustAnother_cummins_guy
Wanted To Buy (WTB) - Used
Oct 21, 2014 05:35 PM
myago92
Oct 17, 2014 08:50 AM
