fuel pressure regulator for piston pump
Old Jul 25, 2010 | 05:53 PM
stillcummin's Avatar
Default fuel pressure regulator for piston pump
What regulator are you guys using for the 2nd gen liftpumps?I got one real cheap,And i was wondering if i could make a regulator for the system.
I was also wonderingf if anyone has successfully changed or altered the spring internally to something lighter to drop pressure.I was thinking of grinding some spring off the ends till i hit 15psi when priming.
Last edited by stillcummin; Jul 25, 2010 at 05:53 PM. Reason: Automerged Doublepost
Old Jul 25, 2010 | 07:32 PM
NadirPoint's Avatar
You could try it, but I would dead head it to a gauge with the engine running at 2k rpm before connecting it to the VE. Run a graviy feed from something for testing purposes.
Old Jul 26, 2010 | 02:12 PM
unixcowboy's Avatar
I think a lot are running the Mallory 4307M -
You just need to T in a return line to the tank.
AND it's boost referenced so you should be able to maintain pressure better.
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
veggyoilkid
Nov 10, 2014 12:39 PM
