intake system
Does anyone know of a good intake system other than stock for my pickup. '92 12v cummins. And how much of a difference will a 16cfm turbo housing make compared to stock. EGT's and and performance?????????? thanks JK
BHAF and a home made mount all the way, cheap and easy.
Read through this thread, BHAF part numbers and the template for the mount are in it.
https://www.dieselbombers.com/1st-ge...7-air-box.html
i used a peice of 4" exhaust elbow to clear the alternatore then just put the biggest filter i could. for the air horn found a free 2nd gen piece with a few silicone parts fits like a glove. as far as milage improvments ? hard to tell with your foot finding the floor constantly
I used a piece of 5" I had laying around from my exhaust system.
By cutting off about 7" or so of the stock bellows intake at the turbo end I was able to connect to the turbo, slide the cutoff portion into the 5" - VERY tight fit - and on the other end, again, cut off about 7" of the stock bellows at the filter end and force it into the 5" then slip a piece 2" long cut off a 4" PVC pipe connector and slide that into the AmsOil 4510 dry filter.
All parts fit nice and tight. In fact I have to completely disassemble the heat shield to clean the filter - but I only do that every 6 mos or so.
I also made up an intake shield that fits the front fender curve and the top slides up under the lip on the top of the fender PLUS there's a back to close it all off. I've got a pyro tip under there and the temps stay about 15* above outside temps. When I get a chance I'm going to get some stick-on insulation and cover the whole inside to try to drop the temps some more.
IceBox makes some REAL nice set-ups!
carid
Diesel Bombers Sponsors
Nov 2, 2015 09:58 AM
jrsavoie
Feb 6, 2015 09:44 PM
carid
Group Buy
Feb 2, 2015 02:54 AM
