Hard-to-Start/No Start '90 CTD
Old Jul 24, 2010 | 10:18 PM
oneloudskunk's Avatar
Default Hard-to-Start/No Start '90 CTD
I have a '90 D250 that's bone stock and has been progressively getting harder to start. A couple weeks ago, it wouldn't start at all and left my dad stranded in Warren. We've been able to get it to fire on starting fluid, then it idles, runs and drives perfect. No excessive smoke (white or black) while cranking or driving. The fuel filter has been replaced along with a new mechanical supply pump. I've had a "Cummins tech" look at it and he's telling me that the injection pump needs rebuilt. I'm having a hard time believing him because the truck runs perfect once it fires, again, with no smoke. I recently installed a clear in-line filter on the suction side of the supply pump. When the engine is running, you can see bubbles suck through the filter every now and then. Sooo...could air leaking into the supply lines prior to my supply pump be the culprit, or do I really need to tear into the injection pump?
Thanks,
-rob
Old Jul 24, 2010 | 10:36 PM
NadirPoint's Avatar
Air leak upstream of the LP, obviously.
Probably only does it after sitting overnight, right?
I'd look into finding the air leak and getting a new "Cummins tech."
Old Jul 24, 2010 | 11:38 PM
Onemoparnut's Avatar
X2!!!!
Old Jul 25, 2010 | 08:54 AM
RSWORDS's Avatar
Very good info in here, and I love how with most self proclaimed "cummins specialists" if you have a no-start its always the pump that needs rebuilt...
Old Jul 25, 2010 | 02:38 PM
Try putting air pressure in the fuel tank. Wrap a rag around a blow gun and stick it in the filler neck. Then look for fuel leaking somewhere.
Old Jul 25, 2010 | 02:41 PM
RSWORDS's Avatar
That works but don't use to much pressure...
Old Jul 25, 2010 | 04:18 PM
yea only maybe 1 or 2 psi sorry I forgot that part.
Old Jul 25, 2010 | 05:34 PM
stillcummin's Avatar
maybe a bad battery.Try startup with a charger one morning
Old Jul 27, 2010 | 09:28 PM
BRILLIANT!!! I did this and found the leak. Unfortunately it's between the tank and frame. Pulled the tank earlier this evening. On may way to having my diesel back! Thanks!!!
Sarcasm...right?
Old Jul 30, 2010 | 12:00 AM
1stGen1990's Avatar
Sounds like it could be your spark plugs to me
Last edited by 1stGen1990; Jul 30, 2010 at 12:00 AM. Reason: Automerged Doublepost
