which lift pump should I go with???
Old Jul 24, 2010 | 03:35 PM
tpa_98Ram's Avatar
Default which lift pump should I go with???
I have a 98 dodge ram 2500 24v. I wanna change out the stock lift pump but don't know what to choose. I'm not looking to build a race or pull truck but I do want to add a lil more power with fuel economy and dependabilty in mind. Now I've seen replacement lift pumps to the Air dog 150 and the fass versions as well. Here's kinda what I want to do to my truck I just need some input from you guys to let me know if the fass replacement lift pump sufficient enough or do I need something more like the airdog 150. I'm just pretty much just want to do all the bolt ons, stock turbo and ip, edge juice. Nothing to crazy but I would like to see around 300-400 hp and 500-600 ft/lbs torque. Let me know what you think and maybe what you have done and the kind of power you gained also what fuel system you think is best and why. Thanks guys!
Old Jul 24, 2010 | 03:51 PM
98dodgecummins's Avatar
dont get the fass direct replacement they dont hold pressure very well. for the money get the raptor 100 150 for around 380 bucks.
Old Jul 24, 2010 | 03:55 PM
biged681985's Avatar
imo, id go with an airdog 150. gives ya plenty of fuel for what ever u end up doing, cause if ur like most of us, u will get used to it, and want a lil more power, and a lil more, and so on. also does a better job of filtering ur fuel
Old Jul 24, 2010 | 03:57 PM
ajayjay's Avatar
If its running right than a lift pump will provide no additional power. Its only there to provide fuel to the injection pump.
Old Jul 24, 2010 | 04:19 PM
tpa_98Ram's Avatar
I know the purpose the lift pump and what it does I just want to know what would work best for the set up I wanna run
where would be the best place to get a 150?
Old Jul 24, 2010 | 04:23 PM
BlackCloud96's Avatar
talk to luke at dieseldawgs.com
Old Jul 24, 2010 | 05:03 PM
tpa_98Ram's Avatar
will do...thanks!
Old Jul 24, 2010 | 07:15 PM
00' Quad Cab's Avatar
I went with the Raptor 150 mounted down on the frame rail, works very well so far.
I have not seen it drop below 15 Lbs. at WOT.
Old Jul 24, 2010 | 07:39 PM
You won't be dissapointed with the Airdog, Airdog 2 or Raptor.
Luke
HeavyChevy95
Dec 21, 2016 10:36 PM
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
