Hard Starting When Warm
Old Jul 24, 2010 | 02:38 AM
mainman300's Avatar
Default Hard Starting When Warm
Has anyone had this issue? I have no codes, great fp. it starts great when i first fire it up but after running for a while she doesent wanna start.
Old Jul 24, 2010 | 04:13 AM
Uncle Bubba's Avatar
You really don't wanna ask this question cause your gonna get an answer that your not gonna like.
It's not the only possibility but the most likely problem is your VP44 is goin out. It's one of the most common symptoms of it and no codes is not unusual.
Old Jul 24, 2010 | 10:12 AM
24vcumminscowboy's Avatar
another thing to check is if ur tank is vapor locked i know on mine on a hot day its hard to start but just go unscrew ur gas cap and listen for pressure being released.
Old Jul 24, 2010 | 10:46 AM
If this is your problem it's an easy fix. Your rollover valve in the fuel tank is plugged up. Snap the old one out and snap a new one in.
Old Jul 24, 2010 | 01:00 PM
mainman300's Avatar
thanks, I had a feeling my vp could be failing, I will check the roll over valve first. I wont replace my vp intell she is dead
Old Jul 24, 2010 | 03:40 PM
If you go to your local Bosch Service center they can plug a code reader into your VP44 and tell you exactly what the problem is if there is one with it. Only Bosch can reads these codes, even Dodge can't do it.
Old Jul 24, 2010 | 03:59 PM
ajayjay's Avatar
sounds like its loosing residual fuel pressure
Old Jul 24, 2010 | 04:44 PM
This wouldn't happen only when warm, it would be at random or a constant. Happening only when warm is an electronic issue of some sort.
Old Jul 24, 2010 | 07:20 PM
00' Quad Cab's Avatar
If it is the VP, it sounds like the circuit board is overheating and locking up.
Just my $.02
Old Jul 24, 2010 | 07:37 PM
where can u get those at
