Sorta EMERGENCY! 03 versus 05 turbo??
Old Jul 23, 2010 | 10:04 PM
Cummins01's Avatar
Default Sorta EMERGENCY! 03 versus 05 turbo??
Well we really in a pinch and need a turbo for an 05. Would the turbo from my 03 automatic(341) work on the 05??(351) what all problems would that cause if any?? Would it even fit on?
Thanks!!!
Old Jul 23, 2010 | 10:20 PM
kmkdiesel's Avatar
biggest difference the 03 has a mechanical wastegate and the 05 has an electrical controlled wastegate.
Old Jul 23, 2010 | 10:58 PM
Cummins01's Avatar
So what happens or what are the symtoms if the wastegate or selenoid goes bad?? We have a LOUD air noise! High egts and max of like 30psi of really sluggish boost.(with his xzt 2 he usually sees 38 or so)
Old Jul 24, 2010 | 12:33 PM
dezeldoc's Avatar
Check all the boots on the intercooler and intake amd make sure none are loose, that is where i would start.
Old Jul 24, 2010 | 10:27 PM
Cummins01's Avatar
All the boots and piping is good that we can find. Is there any way the intercooler could be internally damaged?
Old Jul 28, 2010 | 01:36 PM
dezeldoc's Avatar
Do you have the plastic sided intercooler? if so it may have lost a seal.
Old Jul 28, 2010 | 03:34 PM
bobcat67's Avatar
i believe the majority of the 05 intercoolers are the plastic sided ones, at least that's what i've seen
but i think the turbo will bolt up i just would almost bet it would throw a code unless you have the little fooler that makes the truck think the electronic wastegate is still there
Old Jul 28, 2010 | 10:30 PM
dezeldoc's Avatar
Yep the plastic ones don't like a lot of boost, i have seen them split, blow out the o ring and burst. first thing i did when i got my 05 was replace the intercooler.
Old Aug 2, 2010 | 10:54 PM
Cummins01's Avatar
Thanks a lot guys!! Got the problem solved... It was the intercooler. The aluminum part that crimped over the plastic part had blown apart... Such a wonderful design!!
The reason I was calling it an emergency is cause there was a kid wanting to buy the truck the next couple days and we wanted to get it fixed asap...
THANKS AGAIN!!!
Old Aug 3, 2010 | 03:01 AM
dezeldoc's Avatar
HeHe right again.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
