Okay guys just tell me what to do GETRAG 360 is trashed
Old Jul 22, 2010 | 07:28 PM
boomerjosh's Avatar
Default Okay guys just tell me what to do GETRAG 360 is trashed
so my tranny pretty much needs to be rebuilt...got some major damage goin on in there....it's already out of the truck. what i need addvice for is...weather i should try and rebuild the one i have... or buy a rebuit one.....or what i don't know but im trying not to spend alot of money but it looks like thats not going to be easy.....i know that guys do the nv4500 swap but i don't think i want to do that......please any advice would be great! cuz im pretty much stumped.
Old Jul 22, 2010 | 07:31 PM
12vcummins96's Avatar
get a used one if you wanna go cheap or get it rebuilt
Old Jul 22, 2010 | 09:08 PM
tltruckparts's Avatar
i drive a 2001 dodge diesel 4x4 with an nv4500 at work and i love it compared to my getrag. its much more driveable IMO. i would personally swap it out
Old Jul 23, 2010 | 08:02 AM
Budgreen's Avatar
find a 10spd!
I would look at the cost and your time to rebuild it vs. buying a rebuilt one.
Old Jul 23, 2010 | 08:42 AM
RSWORDS's Avatar
There is a manual In the sticky for the rag. I don't think its all that hard to rebuild yourself if you have any skill at all. That would be cheapest.
Old Jul 23, 2010 | 09:40 AM
boomerjosh's Avatar
where could i get ahold of a rebuild kit? how much cost?
Old Jul 25, 2010 | 09:29 AM
freak007's Avatar
I got my bearing/syncro kit from Zumbrota Bearing and Gear. They have good prices and great service. Motive Gear also has alot of G360 parts, and their proces are cheaper, but they did not have everything I needed... Zumbrota had everything and worked with me on pricing...
When I rebuilt mine I wound up needing several "hard" parts (input shaft, and several gears), and my total rebuild was still well under $500
Get a manual, disassemble and inspect, then call Zumbrota
Old Jul 25, 2010 | 11:59 AM
RSWORDS's Avatar
Sounds like great advice!
Old Aug 1, 2010 | 10:02 AM
Mark Nixon's Avatar
Another sound bit of advice:
EVERY Getrag is a CORE until you inspect it very closely and at least re-bearing it.
I've gotten so many that were "good" and found to be total garbage, that my top paying $$ for one is maxed at $300 as a CORE.
I've rejected many.
The bare minimum you should expect to put into a Getrag is at least a set of bearings and, 90% of the time, an input shaft.
NEW SYNCHRO RINGS are also mandatory, IMO.
Whatever you do, when shimming the rear housing, DO NOT preload them any tighter than the maximum specs, they don't like it and they WILL bite you in the butt if you do it.
Looser isn't necessarily a bad thing in this case.
Craig at Zumbrota is an inspiration to how a GOOD, KNOWLEDGEABLE salesman operates.
Zumbrota is a class A operation in my book!
Mark.
Old Aug 1, 2010 | 10:15 AM
white93's Avatar
There was a guy on ebay selling rebuilt getrags for $1000,but I haven't seen any feed back on how good it is.
ffmoofus
Jul 25, 2015 10:35 PM
