2001-2004 Duramax LB7 blocks, cranks & multiple parts (Acworth, GA)
Old Jul 20, 2010 | 12:55 PM
billyrb's Avatar
Default 2001-2004 Duramax LB7 blocks, cranks & multiple parts (Acworth, GA)
I have remnants from 5 motors still available and would like to start clearing out the garage and making room for my projects. These are all parts from 2001-2004 LB7 Duramax 6.6L motors. They each had around 175k when pulled, and mostly were head-gasket issue motors (1 threw a rod in the bottom). Everything that is usable & in good shape is listed here.
If you need photos of a specific part, let me know and I’ll be glad to take / post them.
Prices listed are “each” and do not include shipping, unless otherwise noted.
AVAILABLE LIST (plus shipping):
Accessory brackets (2 or 3 avail) $15
Alternator bracketry (2 avail) $20
balancer (4 available) $15
bare block (3 available) $150
cam (4 available) $35
outlet water pipe to rad (3 available) $30
Cp3 (has cosmetic blemish) $200 shipped
Cp3 (non-blemish unit) $225 shipped
crankshaft (3 available) $100
downpipe (2 avail) $30
exhaust driver (3 avail) $10
exhaust pass (3 avail) $10
fuel rails (Bosch) $25
Glow Plug Module (2 avail) $35
intake manifold covers (2 sets avail) $15 a set
lifters (3 sets avail) $10 a set
oil pan lower (2 avail) $50
oil pump (4 avail) $20
outlet water pipe to rad (3 avail) $30
Pistons $60 for set of 7 (one was damaged)
Pistons $75 for a set of 8 (dirty, but in good shape)
pushrods (set) $35
rocker arm/ bridges (2 sets avail) $35
rocker arm cover (lower) (2 avail) $25
rocker arm covers (upper) (2 avail) $30
Rods (3 sets avail) $60 a set
Rods (1 was broken, but the rest are in good shape) $40 for 7qty
thermostat housing (2 avail) $15
timing cover (2 or 3 avail) $35
Turbo (IHI) with slight end-play $150
up-pipe driver side (2 or 3 avail) $30
valve caps $15
water pump (3 avail) $25
wiring (top of engine) $25
I will give discounts if you buy multiple items, and will combine items to save on shipping costs when & where possible.
If there is something you want that isn't listed, just shoot me an email (ryan@bilsonassociates.com), PM me here or post up. I can ship anywhere, and use USPS for anything that can go in a flat-rate box, UPS for anything too big for flat-rate, and will use Nationwide Engine Freight Service for the bare block and any components with it (just used that for another block for a guy in Canada, they charge around $250 or so). The parts are located in Acworth, GA 30101.
I accept payments via paypal at ryan@bilsonassociates.com. When you send payment, please include your shipping address & note if it's a business or residential. Also please list the part(s) that you are buying. Of course, contact me before making any payments
Oleoleson
Chevy/GMC Duramax 01-04 LB7
Mar 28, 2015 06:20 PM
