problems with bd stealth plate
Old Jul 19, 2010 | 09:31 PM
4 cummins power's Avatar
Default problems with bd stealth plate
i am having a problem keeping a good connection with my stealth plate for some reason i have to go and adjust wire at the pump every 3-4 months keeps losing connection seems that the screw still has connection but wire has no power readjust the wire and bam power again has anyone else had this problem is there any way to fix it i was thinking about putting the eyelet between two nuts and jam nutting together if anyone has any better ideals feel free to chime in any info would be great guys thanks in advance
Old Jul 19, 2010 | 10:28 PM
https://www.dieselbombers.com/5-9l-2...e-install.html
Old Jul 19, 2010 | 11:02 PM
RAW's Avatar
RAW
I have had mine on since I wrote that thread, December 29, 2009, and have had no problems at all. I did solder my eyelit to the wire from my Edge, you just can't see it with the heat shrink over it. I did not clamp mine between two nuts, just between the stealth plate, and one nut. I held the tapping screw while tightening the nut to prevent over tapping.
You could clamp it between two nuts, or use blue Loc-Tite on the threads to hold the nut in place. There is a possibility that the Loc-Tite will add resistance to your connection though.
Best of luck with a solution.
Old Jul 20, 2010 | 12:49 PM
LawnScum's Avatar
ive had mine on for about 5 months now and never had a problem. i turned the key on and put a testlight in the probe. when i got power to it i turned the probe another 360 degrees
Old Aug 8, 2010 | 03:24 PM
i took mine apart reset allen piercing set screw run one nut down and tightened aginst plate put wire on then put on another nut like a jam nut working great so far thanks for the info guys
Old Aug 8, 2010 | 06:05 PM
RAW's Avatar
RAW
Sounds good, hope it holds up for ya!
Ol Goat
Jan 22, 2015 02:16 AM
SMatyac
Nov 15, 2014 07:35 PM
JustAnother_cummins_guy
Nov 10, 2014 09:44 PM
hardeercy
Nov 6, 2014 08:08 PM
12v_freak
5.9L 12V Performance
9
Oct 10, 2014 02:33 PM
