150's
Old Jul 19, 2010 | 12:25 PM
scottywiest's Avatar
Default 150's
im lookin at gettin a set of smokem 150's but with what i got in my sig do you think i will be alrite??? or am i gonna burn something up??
Old Jul 19, 2010 | 02:35 PM
jl99cummins's Avatar
you will have to turn the quad. down but go ahead an buy them, then buy a bigger turbo
Old Jul 19, 2010 | 09:08 PM
yea im tryin to find an hx35 or 40 for sale rite now bc money is tight but i want me some smokem 150's and hopefully oneday a set of twins then ill prolly upgrade to like 250's
Old Jul 19, 2010 | 11:05 PM
RAW's Avatar
RAW
Wow, you really like smoke, eh? I'm running 65's, and looking for more air before I jump up to 150's. I'm really happy with my 65's. There is a massive difference between my stockers and these one. Especially since the stockers had 305,000kms on them.
Old Jul 20, 2010 | 12:51 PM
LawnScum's Avatar
i just installed my old 150s in a friends 01 with just intake exaust and edge JWA. keep your box down and keep your eye on the egt gause and you should be alright.
Old Jul 20, 2010 | 02:59 PM
Running a good injector makes all the difference. You should be fine.
Old Jul 23, 2010 | 10:46 PM
Prowelder's Avatar
I'm running matched 150s from Diesel Auto Power and they work very well. Smoke isn't too bad and temps are controllable if you know how to drive. My Edge isn't tapped so that helps, but just keep yours turned down/ off and you'll be fine. I got a bigger hit with the new sticks and untapped pump, than tapped pump with stock sticks. The reason mine isn't tapped is due to the VP warranty, that I just had to replace under warranty. So I won't be tapping mine anytime soon due to that.
Old Jul 24, 2010 | 09:53 PM
dennhop's Avatar
Don't go with an hx35...it's not going to help you enough. I'd hold off on the turbo until you have enough to get something bigger...62/71/14, 62/65/14, something like that. I was runnin an edge comp with my 150s when I first got them and I couldn't do hardly anything without blowing a ton of smoke with them, since my stock hx35 couldn't keep up with the added fuel. You can run them, but don't waste your money on an HX upgrade.
