coolant leak
Old Jul 19, 2010 | 09:10 AM
pair60's Avatar
Default coolant leak
Hi
My f250 diesel is loosing coolant,egr cooler was changed by ford a year ago but the oil cooler was not.I recently purchaced this 2004 ford,I've been loosing about 3 liters /tank
any ideas!!
Old Jul 19, 2010 | 10:05 AM
12vcummins96's Avatar
sounds like a blown head gasket
Old Jul 19, 2010 | 10:14 AM
pair60's Avatar
Hi
Pressure tested and not a head gsket,also no coolant in oil pan
Old Jul 19, 2010 | 08:29 PM
newman's Avatar
What is your EOT and ECT? you probably have a bad oil cooler which has caused your EGR cooler to over heat and fail also.
Old Jul 19, 2010 | 09:51 PM
totalchaos's Avatar
pull egr valve out and see if it or the intake has any signs of coolant if it does then its the egr cooler again
Old Jul 20, 2010 | 08:55 AM
pair60's Avatar
Hi
Not sure what the EOT and ECT ,but I know that the oil cooler was not changed when the egr cooler was changed. I know that Ford didn't change both in the beginning but now they do for tht same problem
Your probably correct in saying that it could be the oil cooler. I will bring it back to ford,to see if they can somehow still warrenty it if it is in fact the oil cooler.
will let you know !!Thanks
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
throttleup22
May 2, 2015 02:04 PM
Mike0885
Feb 28, 2015 03:16 PM
merdth6
Nov 20, 2014 08:01 PM
dieseldummy
6.2L & 6.5L Performance
Oct 1, 2014 07:51 AM
