Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
Engine code help
Old Jul 18, 2010 | 08:52 PM
roam1974's Avatar
Default Engine code help
My o5 duramax just started putting out three codes. I am looking for help with where to start looking. Codes are P0700 Trans control sys malfunction, U0073 Control module comm. bus off, U0100 Lost comm. with ECM/PCM module A. Any help would be appreciated....Thanks
Old Jun 8, 2011 | 03:21 PM
Pete Nor's Avatar
Default Codes 0073 and 0100
You need to check the buss bar fuse under the fuse panel under the right front side of your hood. It is a 100 Amp fuse that you must take the curved brace off to check. Release the main fuse box clips and you should see it. When that fuse blows the transmission cannot communicate to the ECM. Hope this helps you.
Old Jun 9, 2011 | 07:51 AM
Rttoys's Avatar
Hopefully he's already fixed it within the last year.
burndiesel
10
Feb 7, 2023 01:15 AM
klein444
Jun 20, 2015 11:48 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
