Fuel pressure problems
Old Jul 18, 2010 | 07:04 PM
06cumminz's Avatar
Default Fuel pressure problems
I have a 93 12 valve auto with PODs, timing advanced, intake, compressor upgrade. I installed a fuel cooler and a mechanical fuel pressure gauge, I only have 6psi at idle and 5psi at WOT, plus the needle is always bouncing around, any solutions?
Thanks
Old Jul 18, 2010 | 07:35 PM
RSWORDS's Avatar
Those numbers are right on par for a stock lift pump. Real good considering the bigger injectors. If you get turning the power up much more you will see the pressure drop right out to 0psi.
If you want more pressure the front seal will take 15-18psi before having issues. Bucnh of solutions from an air dog or FASS to a walbro 392 and a factory low pressure piston lift pump.
Here is my Walbor 392 install
https://www.dieselbombers.com/5-9l-r...e-install.html
And BC847's low pressure piston pump install
https://www.dieselbombers.com/5-9l-r...tml#post409576
gillespie3033
Chevy/GMC Duramax 01-04 LB7
29
Jun 25, 2015 03:51 PM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
