white smoke
Old Jul 18, 2010 | 04:42 PM
alejandro70's Avatar
Default white smoke
the past 3 days my truck has been blowing out white smoke when i take off and when its ideling...any idea's what could be the problem?
Old Jul 18, 2010 | 04:55 PM
BlackCloud96's Avatar
white smoke you say.............. head gasket
check the oil see if there is anti-freeze in your oil or check rad might have oil in anti-freeze
Last edited by BlackCloud96; Jul 18, 2010 at 04:55 PM. Reason: Automerged Doublepost
Old Jul 19, 2010 | 09:41 PM
joey's Avatar
injector white smoke is raw fuel mine white smokes when its cold and i get on it. does it do it all the time or only when its cold?
Old Jul 19, 2010 | 09:56 PM
Dave59's Avatar
Would be head gasket on a Gas engine, not only thing it could be on a Diesel ! May just be water in your fuel, have you changed your filter lately? Air in your lines will make light gray. Don't panic, it's prob. not anything bad. Change your fuel filter, bleed your lines, and go from there.
Old Jul 19, 2010 | 10:22 PM
Slipped timing or bad overflow valve
http://www.dodgeram.org/tech/dsl/tro...p.htm#Overflow
http://dodgeram.info/tsb/1996/14-07-96.htm
Old Jul 20, 2010 | 04:55 PM
roddyhughes's Avatar
12 valves with the p pump are notorius for sliping timing. the gear is just pressed on the shaft of the pump with a nut. check compression of all cylinders. coolant system pressure test.
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
sgreen3
Feb 24, 2015 03:34 PM
zoomer10h
Feb 6, 2015 01:38 AM
