a/c problems
Old Jul 18, 2010 | 02:24 AM
tpost's Avatar
Default a/c problems
my a/c was working just fine then the other day when i started the truck after work it started to blow cold then turned warmer havent had any problems with it until then any ideas what could be wring could feron of leaked out or gotten hole in line somewhere any help would be helpful its awful hot here in the midwest thanks fot any ideas
Old Jul 18, 2010 | 08:06 AM
dustys24valve's Avatar
could be anything.....compressor died, lost freon, bad controls, blown fuse, bad relay.....does the compressor turn on and off rapidly......need more info for better help
Old Jul 18, 2010 | 10:27 AM
tltruckparts's Avatar
check to see if the clutch on the compressor is engaging first. and if oyu have access to a good set of gauges hook it up and see what your freon pressures are
Maclain Marsh
Jul 13, 2015 06:23 PM
CumminsCoalRoller24/7
May 5, 2015 08:55 PM
Zachbishop
Feb 10, 2015 10:23 AM
ChgoSquad5
Ford Powerstroke 2011-Up 6.7L
Jan 6, 2015 11:37 PM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
