Bought an S300
Old Jul 17, 2010 | 09:10 AM
hiboy_76's Avatar
Default Bought an S300
I just bought an S300 off my buddy for $250. It came off a 3116 Cat, it spins freely and has basically no shaft play. There is only two things that kinda other me.
1. There is a little piece of the compressor wheel broke off. one of the fins has a corner broke off but all the rest look fine.
2. The waste gate is stuck. i think its stuck closed because the truck he pulled it off of was sitting in a junk yard.
Also, would anybody know the specs on it? (**/**/**) and do you guys think it would be a good turbo?
Old Jul 21, 2010 | 06:39 PM
hiboy_76's Avatar
my neighbor told me that my motor wont push enough oil pressure to lube this thing properly. is that true??
Old Jul 22, 2010 | 01:01 AM
mopowa's Avatar
guys are pushing enough oil for twins around here so i'd say you definitely have enough oil pressure for that single
Old Aug 15, 2010 | 08:36 PM
tower_ofpower's Avatar
S300's are a pretty common turbo upgrade from what i've seen. since you picked the turbo up for only 250 bucks i'd look into getting a new compressor wheel and doing the job right. even a little bit of an imbalance can cause excessive wear or catastrophic failure due to a weakened/cracked fin, oiling shouldnt be an issue. take the wastegate actuator loose and see if the rod moves freely, if not lots of PB blaster and some emory cloth on the rod will do wonders, nice find
Old Aug 15, 2010 | 09:11 PM
Begle1's Avatar
Depending on the CPL of the engine (or whatever Cat uses), the geometry of the turbo might be perfect or unusable.
I've seen a chunk of one corner of the wheel missing before... Are we sure that's not a balancing notch?
Oil pressure is no problem at all.
Old Aug 20, 2010 | 12:39 PM
hiboy_76's Avatar
heres the pics of the turbo. it doesnt have a wastegate accuator on it.
Old Aug 20, 2010 | 12:51 PM
bobcat67's Avatar
that looks like it'll be fun to spool
Old Aug 20, 2010 | 02:01 PM
mopowa's Avatar
Looks like an s400
Old Aug 21, 2010 | 08:16 AM
hiboy_76's Avatar
i'll get some measurements, but its got T3 exhaust flange, and it looks a little tighter than the H1C.
Old Aug 25, 2010 | 10:39 AM
doesnt look too bad to spool, most of the exhaust housing size can be attributed to the wastegate
