Problem: AC only works through Defrost vents, need Help
Old Jul 17, 2010 | 03:30 PM
Cowboy Cadillac's Avatar
Default Problem: AC only works through Defrost vents, need Help
This all started acouple weeks ago when all the sudden the AC decides to just only work in defrost mode. This went on for a couple weeks then it suddenly worked normal for two or three days. Now it's back to defrost only and it has me stumped.
Being that I have a 2005 F250 lariet all I have are stupid push buttons. There are no manual switches to play with.
Anyone with information on this please let me know..
Any body got any suggestions??
Oh Yeah Move to the top
Last edited by Cowboy Cadillac; Jul 17, 2010 at 03:30 PM. Reason: Automerged Doublepost
Old Jul 18, 2010 | 06:11 AM
scrotom's Avatar
check your hose connections under the hood. small black manifold on passeger fender
Old Jul 18, 2010 | 09:25 AM
Diesel Powered Rocket's Avatar
I've had the small vac pump stop working. It's located on the top of the pass side wheel well. I gave it a tap and it worked until I could get a replacement.
Old Jul 18, 2010 | 10:32 AM
DB Admin's Avatar
Banned
Default Re: Problem: AC only works through Defrost vents, need Help
A vaccum line is off
Old Jul 18, 2010 | 04:41 PM
6.0 kiddo's Avatar
How about your blend door motor? Most automotive heating/cooling systems have a door with an electric motor attached to it that allows to vents to switch between cold air in the hoses to hot air in the hoses. Try switching from heat to AC a couple times and stick your head up under the glove compartment. The blend door is directly under the radio on our trucks i believe. If you hear and electric motor actuating then you know your door is stuck and you can fix that by stripping it down and lubricating it. If you don't hear that electric motor cycle then its time to start stripping the dash!
Old Jul 18, 2010 | 08:33 PM
Mdub707's Avatar
Definitely a vacuum leak. Mine is doing the same thing when switching it to 4x4, and my auto 4x4 doesn't work. It's a vacuum leak.
Old Jul 20, 2010 | 06:52 AM
Ok, its Tuesday morning and still no luck on the A/C problem... For some reason I spent my one day off running the tractor, weedeating, and taking off the trash instead of tinkering on the truck So Thanks to everyone who has helped me out with suggestions so far. Maybe I'll be able to get to it this weekend
Old Jul 23, 2010 | 07:40 PM
Stumblefoot's Avatar
Let us know what you find my 07 is doing that too, but being Over the Road I dont get to see my F250 very often.
Old Jul 24, 2010 | 08:05 PM
baja25sst's Avatar
Default Just had mine fixed-2004 F250 6.0
My hubs would not engage on the fly to 4wd and a/c through defrost. Thought I had a vaccum leak somewhere down by the hubs so I put on Warn Gold hubs anyway as I do not need ESOF. Dealer replaced the a/c regulator I think they called it (in the engine compartment, passenger side, kind of like over the wheel well). All is working great! Hope that helps before you search all over for another leak as I did!
Old Aug 20, 2010 | 01:24 PM
my99's Avatar
Default Same Problem with Defrost ONLY air
Can someone shoot a pic of the part that you found needing replacement ? Seems to be a air control valve issue which, as you know, is related to a vacuum problem. Thx
