strange noise
Old Jul 16, 2010 | 01:17 PM
24vmatt's Avatar
Default strange noise
when i hit 25 psi my truck sounds like it has a blower on it WTF?
Old Jul 16, 2010 | 01:18 PM
RAW's Avatar
RAW
Do you have a boost leak anywhere? Might be a good place to start, tightening a hose clamp can be a very cost efficient repair.
Old Jul 16, 2010 | 01:23 PM
24vmatt's Avatar
i dont think so, i just put new BD intercooler boots and clamps on but i'll check
any other ideas?
Old Jul 16, 2010 | 02:15 PM
RAW's Avatar
RAW
Maybe the exhaust side of things. Blown gaskets or loose bolts. How about the wastegate hose?
Old Jul 19, 2010 | 03:27 PM
24vmatt's Avatar
the wg is pluged off, i dont think the exhaust side is leaking but ill check it out!!!!!
Old Jul 20, 2010 | 08:12 AM
DavidC's Avatar
I blew out my intake manifold gasket once and it did that. Made a crazy whiny whistling sound after I reached 25-30 pounds of boost. This was the gasket on the intake plte to the head, not the one on the intake horn.
Old Jul 20, 2010 | 09:15 AM
chpmnsws6's Avatar
Test the intake system for leaks by capping off the turbo inlet and pressurizing it with an air compressor to 5-6 pounds higher then the highest PSI you hit. Remember to adjust your compressor so your not constantly having to watch the gauge! A squirt bottle with soapy water will work wonders. Wherever it makes bubbles, you have a leak.
Old Jul 20, 2010 | 09:37 PM
24vmatt's Avatar
tanks for the info
Old Jul 23, 2010 | 12:41 PM
luke46's Avatar
Did you find anything out? Mine is doing the exact same thing right now.
Old Jul 28, 2010 | 04:17 PM
24vmatt's Avatar
i havent had time to look into it, but i did notice it only does it when the air is on..
