2002 Cummins
Old Oct 6, 2007 | 06:16 PM
nccummins's Avatar
Default 2002 Cummins
Got a 2002 Cummins 5.9 with right at 108,000 miles on it. I recently put on an edge with attitude, magnaflow, afe stage 2, and a fass fuel system. My question is, how long should a stock tranny last? Around this millage? because mine is about out?
thanks
-Chris
Old Oct 6, 2007 | 06:28 PM
Benjamin's Avatar
Bombardier
your tranny will last as long as YOU want it to. if it is worked like it was intended at stock HP rating it'll last 150-200K miles no problem. but with those mods and "making sure they still work" it'll make the stock tranny's life alot shorter. mine in my 96 lasted to 150K and there was 70K of hard abuse.... i know others will chime in soon. and there are many aftermarket tranny shops out there and they all have their weaknesses and strenghtes. i wouldn't settle for a stock rebuild... get atleast a converter and a valvebody...
Old Oct 6, 2007 | 06:46 PM
Stay away from the 3-5th settings of your Attitude. My Edge Comp box trashed my stock tranny at 85,000 miles. Make sure you get your tranny built right the first time.
Old Oct 6, 2007 | 06:54 PM
Wyatt Earp's Avatar
If it is an auto you are about done after you play a month or two. If it is a stick your clutch will likely start to slip under hard acceleration and high power settings.
Old Oct 7, 2007 | 11:49 AM
2141pete's Avatar
only took mine one trip on the hiyway (stupid level 5 )
Old Oct 7, 2007 | 02:30 PM
Old Oct 7, 2007 | 04:04 PM
nccummins's Avatar
i play on it all the time from 3 - 5.only felt it slip once on the highway....if i keep it on level 1 - 3 it is fine. So pretty much I can either get one now, or at 150,000. So all my buddys sent me to this guy who build diesel drag trannys. He is going to build me one with a triple disc converter, deep pan, VBX valve body, red line race cluth, and some other things here and there for $2,200! Sounded like a good prive to me for sure!
Old Oct 7, 2007 | 04:29 PM
Nice price..... where in NC are you?
Old Oct 12, 2007 | 09:27 AM
Mopar1973Man's Avatar
Hmmm... I'm thankful that I got a 5 speed...
But as for the AUTO series... Anytime you start producing more power than stock with a AUTO TRANS you need to look at get it built. It is for sure the weak link in the chain. There is several articles about pump pressures etc...
Don't go cheap here...
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
Shadow644
Potential Diesel Owners Forum
Feb 5, 2015 07:48 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
