Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
need some tips
Old Jul 13, 2010 | 10:02 PM
hulse09's Avatar
Default need some tips
i have an 00 dodge 2500 5speed with a edge comp drag box raptor liftpump 150gph coldair intake southbend clutch ratted for 500 hp and i think 1100ftlb. or what im wondering is what gear to pull in. ppl are telling me 3rd low and to ride the clutch a lil bit to get going then give her hell. just would like some other advice if you have any. thanks
Old Jul 13, 2010 | 10:39 PM
J-Pipes's Avatar
That actually sounds like good advice, just don't ride the clutch too long or you will roach it! Good luck it's fun
Old Jul 13, 2010 | 11:16 PM
Red_Rattler's Avatar
High Tech Redneck
Yup slip it outa the hole with a good dose of throttle then let it engauge and floor it
Old Jul 14, 2010 | 09:15 AM
94 12valve's Avatar
that single disk is not gonna last very long once you start slipping it.
are you gonna pull on tight or loose tracks?
Old Jul 14, 2010 | 05:05 PM
hulse09's Avatar
tight or loose track??
Old Jul 14, 2010 | 06:09 PM
dirt diggler's Avatar
good clay compacked or loose dirt is what he talking about the tighter the track the better hook you will have. An on the other hand a tight track likes to eat clutches good luck it wont be you last hook
Old Jul 14, 2010 | 07:42 PM
94 12valve's Avatar
Question
yes, sticky or loose would be another way of saying it.
a tighter ( sticky) track will be harder on you driveline in your case either your t case or you single disk clutch will take a beating. It might take a few launches in 3rd low before it starts to slip, if you wanna hook often you should look into a dual disk.
Old Jul 22, 2010 | 05:52 PM
kmkdiesel's Avatar
if you wanna smoke your clutch try 3rd and slip it off the line, if you wanna keep you clutch good start in 2nd gear and dont throttle it, tell fully released.
Old Jul 22, 2010 | 09:02 PM
94 12valve's Avatar
2nd low range is a very slow gear ... no real point in hooking
Old Jul 22, 2010 | 09:23 PM
kmkdiesel's Avatar
no real point in hooking with a single, you wont have a chance against someone with a dual disk but if you do pick a gear and do it right so you dont smoke your clutch.
Brappp306
Apr 3, 2015 12:17 AM
JordanR
Feb 28, 2015 03:24 PM
hulse09
Feb 3, 2015 08:18 AM
JordanR
Chevy/GMC Duramax 04.5-05 LLY
Dec 26, 2014 06:17 PM
