A/c Fan control...
Old Jul 12, 2010 | 09:46 PM
shorty's Avatar
Default A/c Fan control...
Okay, I replaced the fan motor because it was making some HORRID noise and would only work on the highest speed setting. Still only working on highest setting, so I replaced the switch panel on the dash and it still only works on highest setting... So I assume that there is a control module somewhere under the dash. Is that correct or am I missing something?
Old Jul 12, 2010 | 10:19 PM
RAW's Avatar
RAW
Yep, there is a resistor pack near the blower motor. I had the same situation when I first bought my truck. Ended up being a solder that had failed. Re soldered it, and had all speeds again.
Check this old thread out:
https://www.dieselbombers.com/24-val...eater-fan.html
Old Jul 14, 2010 | 05:40 PM
shorty's Avatar
SWEEET!!! Thanks!
Old Jul 14, 2010 | 08:29 PM
RAW's Avatar
RAW
No problem at all!! Look forward to hearing what you find.
Old Jul 14, 2010 | 10:42 PM
shorty's Avatar
The solder joint was busted, but the white porcelain is all busted up and half missing, so I replaced it with a new one for $50
burndiesel
10
Feb 7, 2023 01:15 AM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Rbear
May 3, 2015 07:47 PM
robbyS
Apr 16, 2015 02:22 PM
