voltage regulator
Old Jul 10, 2010 | 10:43 PM
cumminsCrazy's Avatar
Default voltage regulator
is the voltage regulator in the alternator or in the computer?
Old Jul 10, 2010 | 11:47 PM
Its in the PCM but you can wire in an external voltage regulator.
What kind of problems are you having?
Old Jul 11, 2010 | 06:30 PM
the gen light is on when im idling it maxes out on the guage but when under a load it goes into the normal range and turns the gen light off im not sure whats going on
Old Jul 13, 2010 | 04:57 PM
bump please help guys
Old Jul 13, 2010 | 07:54 PM
We need voltage numbers from the battery terminals.
Old Jul 13, 2010 | 08:52 PM
okay i tested the alternator and its putting out 14.61 volts could bad batterys cause this condition?
Old Jul 15, 2010 | 05:46 PM
okay so idle i am getting 14.1 volts and 2500rpm im getting 16.30 and bench tested alternator it is good on the tester
Old Jul 15, 2010 | 06:47 PM
The alternator and voltage regulator should be good then.
Weird. Check all your body/frame grounds. Clean all the mounting points. I think there are 7 or 8.
Old Jul 15, 2010 | 06:54 PM
okay ill look for one i might have broken one when replacing the drivers side fender
dang
Old Jul 22, 2010 | 07:04 PM
daredevilkamm's Avatar
my pcm went out and i did the external voltage regulator, mine does the exact same thing.
