strange noise... need help
Old Jul 10, 2010 | 09:07 PM
tpa_98Ram's Avatar
Default strange noise... need help
Hello everyone, before I start with my question let me introduce myself because this is my first post as I am new to DB. My name is Rob and I'm from Tampa, Fl. I just recently purchased my first diesel and it's a 98 Dodge Ram 2500, 5.9L 24v Cummins. I picked the truck up for only $1800 but it's mechanics special at best. The body is in rough shape and the truck has high mileage but when I purchase it seemed to run pretty well. Now after driven it for a week or so it's developed a fuel leak that seemed to be coming from plate the intake is bolted to. So I tightened it and the fuel leak stopped. Now the motor makes a high pitch whining noise when the truck is hitting boost. It doesn't do it at idle or when reving the engine in park but only when the engine is under acceleration. The noise seems to be coming from the driverside which kinda worries me because that's the side the IP is . The truck is bone stock with all original equipment. If anyone has ran into this same situation or who knows what could cause the noise please let me know. I've looked the truck over for a few hours today and cannot figure out what it is...Thanks for any help!
Old Jul 10, 2010 | 09:20 PM
BlackCloud96's Avatar
What kinda noise hissing or like turbo noise check your intercooler boots when your driving your building boost so maybe it might have a leak or a hole or maybe just came off
Old Jul 10, 2010 | 09:33 PM
tpa_98Ram's Avatar
yah I checked the intercooler tubes and didn't see anything suspicous. And the noise isn't like a hissing sound it's kinda like a gear or bearing whine. It's hard to explain but I dont think it's a boost leak.
Old Jul 10, 2010 | 09:37 PM
Billy D's Avatar
Mine make a high pitched whistle at high rpms, but mine sounds like its coming from the turbo side. Same high pitched sound I bet
Old Jul 10, 2010 | 10:11 PM
tpa_98Ram's Avatar
could the injector pump make noise if it's going out and if so would it make the noise i descibed?
Old Jul 11, 2010 | 04:45 AM
Boondockers's Avatar
sounds like a boost leak sqeeze all hose conectors and make sure there not cracked or a loose clamp
Old Jul 11, 2010 | 05:49 AM
thebullet83's Avatar
the vacuum pump and power steering are on that side too.
Old Jul 11, 2010 | 08:04 AM
dodge rodder's Avatar
i thimk the same as bullet83 low power steering fluid would make a graling sound, just something to check
Old Jul 11, 2010 | 08:52 AM
f4ujmb's Avatar
Mine does the same thing but mine is the turbo when it spools up it will not do it unless i put a load on engine .
Old Jul 11, 2010 | 03:44 PM
The thing is the pumps would make that noise all the time not just when he is driving and building boost he said it only does this when he is driving so i would rule those ones out Sorry!
