Brake light issue
Old Jul 10, 2010 | 01:14 PM
big willy's Avatar
Default Brake light issue
Alright i've had this problem with my brake lights for almost the past year know and for some reason nobody around this town can fix it. what happens is whenever i go to hit the brakes and i let back off the pedal wont come all the way back to turn off the toggle switch to kill my lights so i have to drive with my foot under the pedal holding the lights off. Anyone have any ideas or suggestions to fix this problem?
Old Jul 10, 2010 | 03:37 PM
brindle_bull's Avatar
my brothers truck does that and he hooked a bungee strap to it somehow down there to keep it back up but i dont think the actual problem has been looked into
Old Jul 10, 2010 | 07:16 PM
mylilpwny's Avatar
sounds like a pedal problem not lights or light switch problem ... like maybe a bad return spring or something ... some one else will chime in im sure ... but if ur having to hold the pedal up its not the switch
Old Jul 11, 2010 | 12:36 AM
big willy's Avatar
i know its not the switch i want to say its the spring but i've had it replaced about 3 times and it still does it
Old Jul 11, 2010 | 07:20 AM
cummins95's Avatar
its the brake light switch out of adjustment. lay on ur floor n look up at the brake pedal. grab the bracket for the switch with a pair of pliers n bend it toward the pedal a little bit. i've had to do this with mine.
Old Jul 11, 2010 | 01:32 PM
big willy's Avatar
wouldn't i need to bend it away? since the pedal connecting with the switch is what triggers the lights?
Old Jul 13, 2010 | 08:54 PM
cummins95's Avatar
when u push the pedal it goes away from the switch. when u let off it pushes the switch in. i know it seems backwards but take a look at it.
Old Jul 14, 2010 | 04:07 PM
440ctd's Avatar
mine did this also I got a new one and it worked. there was a mid range where it was dead
Old Jul 14, 2010 | 06:05 PM
big willy's Avatar
o yeah i guess your right now that i think about it
Old Jul 14, 2010 | 06:10 PM
cummins95's Avatar
did u try it?
