sputter and white smoke???
Old Jul 9, 2010 | 08:15 PM
dieselhead's Avatar
Question sputter and white smoke???
I was just driving home had it in O/D off i was around 2k rpm gave it a little throttle and it sputtered and white smoke came out the stacks any one know what would cause this? any help would be great thanks
Old Jul 9, 2010 | 08:49 PM
dangerous1965's Avatar
Dead hole or bad injector or hopefully your just sucking air somewhere!
Old Jul 9, 2010 | 09:02 PM
dieselhead's Avatar
if it is a bad injector why doesnt it do it all the time?
Old Jul 10, 2010 | 09:16 PM
dieselhead's Avatar
thats it ?? no one else has ever heard of this?
Old Jul 10, 2010 | 10:16 PM
Blackout_CTD's Avatar
your probably just sucking air somewhere most likely the draw straw
Old Jul 10, 2010 | 10:27 PM
What is your fuel level when this happens?
Old Jul 11, 2010 | 08:13 AM
dieselhead's Avatar
when it first happen it was about 1/8 tank but i filled it up and it still does it. it will only do it if i accl hard if i roll it on it wont do it. if i am going along steady and stab the throttle it will do it but not all the time
Old Jul 12, 2010 | 05:09 PM
cerberus60's Avatar
Check your rail pressure and feed pressure when it happens for problems. Back the Smarty timing and\or SW down and see if that changes anything.
Old Jul 12, 2010 | 05:14 PM
dieselhead's Avatar
allready tried backing down the sw and the timing didnt work
Old Jul 12, 2010 | 09:59 PM
White smoke unburnt fuel. I'm still going for a bad injector!
