Dodge 2001 cummins
Help me boys! Got a 01 cummins 24 valve with 70K on it. Fass pump, Bosch VP44, 150 candles, Banks high ram, super B special turbo, goerends trans (vb and convertor) 4" to 6" stack, Juice with Attitude (on 5) and smarty stacked (tried with and without). Running 285 rubber and can't get truck to break traction from stop. Would like to smoke tires from hole. What else is wrong? How do [I] get smoke off tires from start?
Try to build up some boost before you try to launch the truck......one foot on the brake and slowly give it gas........than let go of the brake and mat it.
Or just light the tires on fire and pull away
Install a line lock on the brake line going to the back end. It will allow you to shut the back brakes off and modulate the brakes on the front end for those sweet rolling tire melters. How will a burnout overspin the turbo?
Shun70
Sep 20, 2015 10:52 PM
