throttle linkage
Old Jul 9, 2010 | 08:35 AM
lopez dodge's Avatar
Default throttle linkage
i broke the plastic end on my linkage at the ic . found some thing that works , but the throttle stuck W/O this morning scared the $hit out of me . any way the new head i found is binding should i just file it down or is there a better option?
Old Jul 9, 2010 | 08:58 AM
jasonfriedlin's Avatar
https://www.dieselbombers.com/1st-ge...ottle-rod.html
Down towards the bottom in my post is the ppart numbers for Cummins. They are pretty cheap.
The new ones from Cummins are also metal and much better quality. I broke my plastic one and glued it back together to get me by
Last edited by jasonfriedlin; Jul 9, 2010 at 08:58 AM. Reason: Automerged Doublepost
Old Jul 9, 2010 | 09:42 AM
NadirPoint's Avatar
This don't cost much either:
http://stuff.is-a-geek.net/PhotoAlbu...cs/CTD_229.jpg
If you have the time to make it, you can be pretty much guaranteed it will never fail.
Old Jul 9, 2010 | 03:58 PM
thanks for the input but since this happened on the way to work I needed to fix it today . went to napa and found some heim joints that would work and made up a linkage on lunch those metal ends look pretty sweet if my brothers truck ever has a problem Thanks.
Old Jul 9, 2010 | 07:48 PM
jimbo486's Avatar
For some reason I get the feeling that the chain is some sort of cruise control?
Old Jul 10, 2010 | 02:36 PM
NadirPoint's Avatar
Originally Posted by jimbo486
...the chain is some sort of cruise control?
It's connected to the one on the left here:
http://stuff.is-a-geek.net/PhotoAlbu...ics/CTD_84.jpg
I call it a hand throttle and use it mostly to high idle for warmup in the winter. But it does make a pretty good cruise control, as well.
12vWoodHauler
Sep 30, 2015 07:58 PM
Blair@BD
BD-Power
Sep 10, 2015 12:29 PM
jmerriman17
Nov 16, 2014 02:13 PM
1stgenswap
Nov 3, 2014 09:45 PM
marks86
Oct 23, 2014 03:25 PM
