Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
Injector Pump??????
Old Jul 8, 2010 | 05:36 PM
mnursery's Avatar
Default Injector Pump??????
I have a 06 gmc with a lbz and no mods.I drove my truck as always, shut it off . when i started again it ran a few seconds an shut down. tried to prime filter no luck. replaced filter and wif checked for leaks non found. still would not prime. towed to dealer, they say the injector pump is at fault. i have a hard time beliving this. plus at a cost of 3k. the truck has 112k miles. and never had an issue. any help would be great.
Old Jul 11, 2010 | 03:12 PM
mnursery's Avatar
Default Found it wif sensor!!!!
Found the problem it was the wif sensor not sealing.Replaced $20 part took truck back to dealer to show them . and asked why it needed a 3k cp3 pump?/??? no reply
Old Aug 21, 2010 | 04:01 PM
captain_stabbin's Avatar
that cracks me up glad you got it back rollin for cheap
Old Oct 7, 2010 | 02:34 PM
AZLBZ's Avatar
WOW, where did you go to buy that seal?
Old Mar 3, 2012 | 10:04 PM
jshel's Avatar
I am having the same problem with my 2004 duramax. Where is the sensor located? shel
Old Mar 3, 2012 | 10:45 PM
H.R.D's Avatar
They are crooks man, glad you figured it out.
Old Mar 3, 2012 | 10:59 PM
AZLBZ's Avatar
I have hado much trouble those pos filters and the poor design that GM/ISUZUI put together. if I wasn't some thing leeking it was something clogged or I was getting the low rial presure code p0087 under heavy load when towing. I bought an air dog fuel preperation sysytem and completely bypassed my stock filter system and I have not had one problem in 25000 miles. Just changed filters.
Old Mar 5, 2012 | 10:50 PM
BriteWhiteRam's Avatar
i've never had an issue with my stock filter
