Turbo questions
Old Jul 8, 2010 | 01:46 PM
Billy D's Avatar
Default Turbo questions
My truck sat fer about 2 months due to needing a VP. I replaced the VP and added a Raptor100 and it seems to be running fine, although theres a whinning coming from what seems to be the turbo area. I put a new AEM cheap dry filter on it, but when I mash the pedal, it increases the rpms, and then I get this high high pitched whistle. It NEVER did it before it sat, could I have a failing turbo? Could it be a bearing? When I mash the throttle my temp gauge increases kind of fast (like 200-210) but I only stay in it fer a second and thats the highest I've seen. I dont have a gauge, im talking about the factory one. Running normal it runs fine, no heat issues, and it's 95 degrees now, its only when I've mashed it those couple times. Could I have wastegate issues, maybe my T-stat going bad What can I check for???
Any info is greatly appreciated
Thanks
Billy D
Old Jul 8, 2010 | 02:13 PM
00CumminsMan's Avatar
Good question. I cant answer that, but my turbo made that same sound.
Old Jul 8, 2010 | 07:53 PM
Billy D's Avatar
Mine starts to run hot as well
Turbos, anyone?
Old Jul 8, 2010 | 07:58 PM
turbo20psi's Avatar
That is normal mine does the same thing but very fast (temp climbing).You have a auto trans? 95 degree air intake is going to make any truck temp climb fast.As for the turbo if it is a hy35 they have aways made noise in the high rpm,I know mine did.You have made the truck happy with the new vp and raptor.
Old Jul 8, 2010 | 08:24 PM
dustys24valve's Avatar
dumb question but is it a boost leak, do your egt's skyrocket?
Old Jul 8, 2010 | 08:25 PM
RAW's Avatar
RAW
A boost leak can produce a high pitched sound. May not be a bad idea to go over all your clamp and check the tightness.
Old Jul 8, 2010 | 10:01 PM
mb5n537's Avatar
mine started making a high pitched squeak one time and check over everything and turned out one of the rubber boots coming off the intercooler was blown open, dodge wanted 160 bucks just for that boot, luckily i found a guy who just upgraded his and gave me his old one. so might want to check that. other then that my turbo squeals real high pitched in high rpms too.
Old Jul 8, 2010 | 11:22 PM
Yes my fucken egt's could hit 1600 if smack on her from a 60 roll Thks for the advice guys. Am goin check over every thing before i put my truck back together
Old Jul 9, 2010 | 03:38 PM
Billy D's Avatar
Thanks everyone
The only gauge I got is a FP gauge, my factory temp gauge goes up to about 200-210. Is that to hot? I checked for leaks, everythings tight, could it be a bearing, do they make noise when they start going out? The shaft seems tight, it spins freely, no crap in it.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
markanthonyhudson
11
Feb 11, 2015 05:49 PM
GreenDieselF
Oct 20, 2014 02:05 PM
