Tanny Temp
Old Jul 7, 2010 | 03:25 PM
foxracingman's Avatar
Default Tanny Temp
Hello, I have a dilemma. My temp. gauge reads that my transmission is running at 250+ degrees and/or or my gauge is maxed out. What should my tranny temp be running at? Any replies would be greatly appreciated. Thanks.
Old Jul 7, 2010 | 03:30 PM
00CumminsMan's Avatar
wow thats not good at all. It should be arond 150-180. Anything over 200 is never good.
Old Jul 7, 2010 | 03:34 PM
JIT's Avatar
JIT
It will usually be about 10-20deg cooler than your engine temp. The tranny cooler lines run through the cooler by the radiator where the engine coolant is and also through the oil cooler on the block. This keeps the fluid warm in the winter so the trans will work properly but dont really help when you want to cool it down... 160-190 is normal.
You may just need a flush and some fresh fluid.
Old Jul 8, 2010 | 11:08 AM
01quadcab's Avatar
if your gauge reads that and your truck is not throwing the warning lite of trans temp, and turning over drive off, I would suspect something is wrong with your gauge.
Old Jul 8, 2010 | 11:21 AM
You leave out some important info...where exactly are you measuring the temp?
I suspect the install may not be right or your guage is buggered, but thats just a guess.
Old Jul 8, 2010 | 12:55 PM
turbo20psi's Avatar
Where is your sending unit at?You need a good ground for the sending unit.Check all the wiring first.
Old Jul 10, 2010 | 11:19 AM
kingbrad89's Avatar
What kind of gauge? I had the same problem at one point and it was an electrical ground throwing the numbers off. Fixed the ground and fixed the problem.
casper83
23
Jul 27, 2015 01:53 PM
doodieroot
May 10, 2015 11:48 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
emilio2496
8
Jan 13, 2015 05:03 PM
mule97
Dec 12, 2014 05:05 AM
