Bed corner repair?
Old Jul 6, 2010 | 08:38 PM
TTipsword's Avatar
Default Bed corner repair?
The corners of my bed are torn up as im sure alot of others have been too. I did re-weld the crack, and in a year they have torn again. Anyone know of a permanent fix for this? I am thinkin about re-welding it again then throwing a bed rail on that will cover the cab side rail, and about 1ft. down the side rail. Would that work if i welded it to the inside rail of the bed? it has me kinda stumped
anyone?
Old Jul 6, 2010 | 08:53 PM
93fatbed's Avatar
Well anything that will add support to it will help. Have you checked to see if your bed bolts are tight. I've also ran into this problem on most of my trucks. But drilling the end of the crack and welding it up has worked for me with no more cracking.
My biggest problem though is the back of the cab cracking. That is a PIA to fix. You gotta take the bed off, and thats never any fun even with a lift!
Good Luck.
Old Jul 6, 2010 | 09:07 PM
TTipsword's Avatar
the cracks are on the corners of the bed. i did drill out the crack and welded em, they then cracked next to the weld
Old Jul 6, 2010 | 09:13 PM
93fatbed's Avatar
Yhea I understand where it's cracking, I was just saying to check the back of the cab also. I think your Idea of making the bed with more support would work and work well. The point is that the bed is flexing out or in and is finding it's weak point and cracking. If you were to tie it all together then it will help with the cracking. Next thought would be to make a head ach rack and bed rails all the way back to the tail gate. Then tie all of that together.
Also make sure everything is tight, if it's flopping around and flexing that would make it crack quicker.
Old Jul 6, 2010 | 09:54 PM
TTipsword's Avatar
ya the only movement i get is from the backside of the bed. it had been pushed back to the cab before i bought the truck wich originally caused the problem. after makin it straight, and the welds not working, i guess what im afraid of is for the bed rails to crack around the rail cap i plan on making for it because i dont want to run them all the way back.
Old Jul 6, 2010 | 10:11 PM
93fatbed's Avatar
Well next thing you may want to start checking around for another bed. If it's been pushed around it may be a diamond now and with the frame moving it may never be right? Either that or build your self a flatbed like all of us cool guys! (One of my trucks has a flatbed, the others are still boxes)
Old Jul 6, 2010 | 10:14 PM
TTipsword's Avatar
i wouldnt mind a flatbed that fit the truck....but i dont hardly have the money to drive the damn thing! anyways thanks for your help
Old Jul 6, 2010 | 10:37 PM
93fatbed's Avatar
I hear that buddy. If only our casino cash here was real! Anyways I hope all turns out well with the truck and you figure out a way to get it all purdy for the ladies. good luck
Old Jul 7, 2010 | 04:28 PM
TTipsword's Avatar
ha ha i dont need to impress any ladies but my own.
Old Jul 7, 2010 | 09:37 PM
93fatbed's Avatar
Well I'm in the same boat but....It's nice to window shop from time to time. I keep telling here when she gets to 40 I'm gonna go and trade her in for two 20's!!!
