Lift Pump Electrical Circuit Issues
Old Jul 6, 2010 | 05:46 AM
twr318's Avatar
Default Lift Pump Electrical Circuit Issues
I just installed a rebuilt VP and AirDog 100 over the weekend. I'm having problems keeping power to my LP. Can I just wire this thing direct with a switch or tie into a circuit that's keyed on? I also bought an Actron CP9180 Scanner. The only code I get is "Crankshaft position sensor". Could this be effecting my fuel pump circuitry? That wouldn't make any sense, but a lot of the circuits on these trucks are screwy! I'm picking up and replacing the Crank PS today. Did the Cam PS while I had the VP off.
Old Jul 6, 2010 | 07:33 AM
RAW's Avatar
RAW
The pump shuts off immediately if the key is on and the engine stops running.
This is directly from a Dodge Tech Manual. I can only assume that if the ECM thinks the engine is not running due to a faulty Crank sensor it will cut power to the LP. Does your tach act funny?
Old Jul 6, 2010 | 11:09 AM
twr318's Avatar
It hasn't worked in a while. Ocassionally it will for a few seconds. I'm replacing the Crank PS today. I'll post if it fixes the problem.
Old Jul 6, 2010 | 02:09 PM
Uncle Bubba's Avatar
Are you still using the stock LP trigger wire for the new pump. If not you should be, and run a relay switch from the battery to the pump for power.
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
robbyS
Apr 16, 2015 02:22 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
