Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
hey i wanna buy this supposable pullin truck. wat you think
Old Jul 5, 2010 | 07:05 PM
Casefarmer's Avatar
Default hey i wanna buy this supposable pullin truck. wat you think
98 Dodge Cummings 12 valve with 580hp. Ready to use in pulls. Needs a new hub bearing on drivers side front and upper and lower ball joints on passenger side front. Must be trailored home bt the buyer. Can not be drove home hub bearing completlly shot.
Regular Cab, Long Bed
12 valve Diesel Moter with:
60 series phat shaft turbo
ATS flex fuel plate
370 marine injecters
Lazer cut delivery valves
Hardend rings and keepers
ARP head studs
It also still has stock tranny in it. Wat do you pullin guys think??? Said he would take 7k for it
Old Jul 5, 2010 | 07:31 PM
Bosshawg600's Avatar
Stock trans.......Aint Holding 580Hp!!!!!!
Sounds like a street truck to me. Id try and get the price droped down a bit if ya can....espacally since you have to traier it home!!!!
The fix's arent that expensive at all, should only take an afternoon to get it going.
Ditch the injectors and get a real set of sticks! Then a good 5K GSK and a better trans and it should be fun to go out a get some hooks in!!!
Old Jul 5, 2010 | 07:40 PM
BlackCloud96's Avatar
I would spend that much for a street truck like boss said stock tranny aint gonna hold!!
Old Jul 5, 2010 | 08:30 PM
Cummins97's Avatar
Correct me if I'm wrong guys, but I don't believe the mods listed equal up to 580 hp, not by a long shot.
Old Jul 5, 2010 | 09:11 PM
spoolinaround's Avatar
maybe with a 300 hp shot of squeeze
Old Jul 6, 2010 | 06:30 PM
Casefarmer's Avatar
yea i will look and take pics then post on here. I not worried bout the tranny cause i got an allison layin around plus a nv 5600 and 4500 so i not worried but dont wanna use one of them on a pullin truck just yet prob but the allison in it. You think it would hold? Wats a good set of injectors to run? why dont i wanna run 370's?
Old Jul 6, 2010 | 07:02 PM
bosch marine 370's are the wrong spray angle/pattern
Old Jul 6, 2010 | 08:20 PM
kmkdiesel's Avatar
Not enough mods to make that much hp that is claimed, especially with the stock auto tranny, I think that turbo is to small to get that much power even with a benched pump and built tranny, and if you did egts would be sky high especially with those lazer cuts. If the rest of the truck is in perfect condition then I would maybe get it but from what he has told you and what is done to the truck I wouldnt even bother with it, cuz who knows what else is wrong, and that is not even close to a pulling truck set up. Also the marine 370's are just that for a marine engine not a pickup truck so the spray pattern is different. They are cheap injectors and do give you a good boost in power, but they run hot and are smokey.
Old Jul 6, 2010 | 08:40 PM
biged681985's Avatar
with that set up, if the trans holds it, maybe 400. but a complete stock trans wont hold 400 hp for a pull, no way. the reason u probably cant drive it home is because the trans is shot. id stay away from it. either make him fix the hub before u buy it, and test drive it, or stay away
Old Jul 6, 2010 | 09:12 PM
Casefarmer's Avatar
http://images.craigslist.org/3k13m43...35832b11d9.jpg
ok theres the url you guys tell me wat you think
