question on buying a 4 inch exhaust
Old Jul 5, 2010 | 03:29 PM
12vcoalroller's Avatar
Default question on buying a 4 inch exhaust
all i need to know is will a 2nd gen exhaust fit a 1st gen? i know the down pipes are different but i can get a good deal off a buddy for a new 2nd gen but dont want a lot of work with it also will 4 inch run over the rear axle of a d250 without any problems? ... i'm tired of building exhaust systems so im trying to keep it cheap and simple
thanks in advance
Old Jul 6, 2010 | 08:37 PM
tltruckparts's Avatar
dont quote me on it but i would assume it would. on my chevy i have the kit from a 94-02 dodge ram. most trucks are built roughly the same as for dimensions so i would think it would at least fit enough to use it and still look better than hacking a bunch of bends together
Old Jul 6, 2010 | 08:49 PM
93fatbed's Avatar
You will be able to, if you hack it up pretty good. Also what turbo are you running? That will make or break you on how the down pipe is. I'm not sure on your definetion of a "good deal" but there are a few companys out there with exhause for a 1st gen under 300$ And then again I've got a total of 70$ in my whole exhasut with mandles and half a day of work. Good Luck
Old Jul 6, 2010 | 09:32 PM
ok cool thanks guys, where can i get an exhaust for under $300 for a first gen? and where and what pipe did you get for your exhaust for $70
Old Jul 6, 2010 | 10:07 PM
93fatbed's Avatar
I made mine. If you talk to an exhaust shop and say you are paying cash most have peices of pipe laying around that they can't use for other projects and what not. I've since added a stack which I did a little gypsy trading for so I'm still under 100 total.
And call up diamond eye for the built system. there are others out there too, just a recent romor I've heard on real cheap from diamond.
I will assume you are still swinging the factory turbo? If so may want to think about holding off on exhaust til you get that figured out. Well..... if you do plan on an windmill upgrade?
At the very lest get rid of the big old muffler and put a donkey dick on the end by the crossmemeber.
Old Jul 7, 2010 | 07:10 PM
DirtyDozen's Avatar
On that 2nd Gen. note: keep in mind that the pumpkin on the fron diff in a 2nd gen. is on the left, and the 1st gen is on the right, so this means that your t-case and driveshaft are stickin' out on the exhaust side, which is a problem that wouldn't be accounted for on the 2nd gen. system, there would be some work needed to adress that for sure.
Old Jul 8, 2010 | 12:33 AM
kensmachine's Avatar
4" exhaust for under 300 get a hold of TV Diesel. Diamond Eye has a new systems for the first Gen trucks P/N K4211A . Check with TV Diesel they had a sale last mouth on then $275 with free shipping. Ken
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
DieselLuver
Aug 3, 2015 12:31 AM
Noodle
Apr 21, 2015 06:43 PM
DirtyMonkey
14
Oct 31, 2014 10:54 AM
